Seattle206
Anyone here have experience replacing the seals/brake shoes on the 5th gens rear axle?
I was getting my air locker serviced and the mechanic found this issue:
"While disassembling the axle I found an unrelated problem which will require immediate attention. Upon removal of the driver’s side rotor I found gear oil had made its way past the axle seal, through the axle bearing, and into the parking brake assembly. To repair this properly requires replacement of all related parts as the oil has contaminated the sealed bearing assembly washing out the grease, and contaminated the brake shoes. This is an involved procedure due to the nature of the design of the parking brake and bearing assembly. I unfortunately do not have the tooling required to perform the repair, though I can refer you to a trusted shop if you don’t already have one. You will want to have this addressed right away as not only will it continue making a mess, you run the risk of starving the differential of oil."
I spoke with Toyota of Seattle and they denied it under the 5 year/60k powertrain warranty. My vehicle is at 42k miles.
I'm going do this job myself and looking the oem parts I'll probably need the following:
(1) HUB & BEARING O-RING - TOYOTA (90301-83002)
(1) HUB & BEARING OIL SEAL - TOYOTA (90310-58004)
(1) SHOES TRAILING- TOYOTA (46540-60060)
(1) SHOES LEADING - TOYOTA (46550-60070)
(1) GEAR OIL
(1) HUB & BEARING - TOYOTA (42450-60050) - Worst case scenario
Any input will be appreciated! Thank you.
(1) GEAR OIL
