Old 07-28-2018, 04:47 PM #16
Agent_Outside Agent_Outside is offline
Agent_Outside is a jewel in the rough Agent_Outside is a jewel in the rough Agent_Outside is a jewel in the rough
Baja Designs Sqaurdron Pro fog light pocket kit. BD is widely thought of as the top dog in the LED game, I may have made a mistake going with the Pro lights. Each pod is 4 LEDs and fits into the factory foglight housing location, and the output is absolutely insane. They are so crazy they aren't usable on the street. They are significantly brighter than high beams.
Not my video, but a good video showing the ridiculous output of the Pros
https://www.youtube.com/watch?v=LgWl...ature=youtu.be
Agent_Outside is offline   Reply With QuoteReply With Quote
Old 07-28-2018, 04:48 PM #17
Suspension
I like the XREAS suspension, the dampeners were linked at opposite corners. LF to RR ad RF to LR. When one dampener is compressed it linked wheel gets pushed downward to try to equalize and level the vehicle. On road it was fantastic, it stayed sports car flat around corners on on/off ramps. Off road it was a bit rough and it fought articulation a bit but overall, I was a fan. I kept the factory stuff until I killed it. Too much time on unpaved washboard rutted up roads at speed did it in. The suspension got hot, really hot, the dampeners faded bad and it started to smell. From that point on the shocks leaked.
This was the day after
So little man and I stopped by Filthy Motorsports in Boulder to do some shopping. They are widely regarded at the go to place for all things King, they are King’s highest volume dealer.
We started the process of getting an order placed. They start with the base “OEM kit” and then factor in vehicle weight, intended use, tire size, ride height, spring rates, control arms, future plans to add weight like steel bumpers and a winch, etc, etc, etc. It was an awesome experience, very detailed, very thorough, or so it seemed…
- 3/8/18 I placed an order through Filthy Motorsports with a “4-6 week lead time”.
- 4/13/18 (4.5 weeks in) I’m told “another 3-4 weeks”.
- 5/9/18 (9 weeks in) I’m told “another 2 weeks”.
- 5/24/18 (11 weeks in) I’m told “a little while longer”.
- 6/5/18 (13 weeks in) I’m told “They’ve finished your order and are preparing to ship it”.
- 6/12/18 (14 weeks in) The suspension shows up at Filthy Motorsports, I tell them I’m out of town but I fly back on Friday 6/22/18 so I’ll come the following Monday morning to pick up the parts.
- 6/13/18 Filthy says “Ok, that should be fine. Please send us another email a few days before with the approximate time that you think you’ll show up. Ben should be inspecting your shocks today and if we discover any issues we will let you know. If you don’t get any more emails from us that will mean everything looked good.”
- 6/22/18 (15+ weeks in) I didn’t hear anything back so I sent a message that I’d come Monday morning around 8:30. They respond back saying the rear shocks are wrong, they aren’t the custom length rears. They said the box and the shocks are tagged as standard off the shelf rears and they are contacting King about it. Later that day Filthy said they talked to King and did some measurements and that they are in fact the correct parts just mislabeled.
- 6/25/18 I finally get my parts and head home to start the install.
After spending a whole bunch of money and waiting 15+ weeks I was happy to have my parts but I can’t say I was happy with how it all went and the issues were just beginning. Both small washers for the slotted holes in front sway bar spacer/reservoir brackets were missing, the front hose clamps to mount the reservoirs were too short, and the rears didn’t come with any clamps at all to mount the reservoirs. I went to the hardware store and got what I needed and continued the install.
If you notice in the above pics there is no preload on the coil overs. Filthy was very specific that they were already set up for a 2.5” lift in front and not to adjust anything, just throw them in and it’s good to go and in a month or so after everything settles you can tweak it if need be. So that’s what I did and it only gaining a little over an inch measured from the center of the hub to the fender edge. I asked Filthy what the deal was, their response was that my vehicle must be spec’d with extra weight than normal and that my before measurements seemed lower than normal to begin with. Knowing full well that was 100% made up BS I called King directly. King said the coil overs will never come set up for a 2.5” lift, they said they come with the spring perches at their lowest height which should be roughly 1.5” higher than stock. They said if you want 2.5” to go with 5 turns on 1 side and 7 on the other as a good starting point while accounting for the typical Toyota lean. That not even close what Filthy said. Remote reservoir Kings need to be removed in order to adjust height, so the suspension came right back out. King also informed me they always advise customers to except about 3 months for custom orders compared to the 4-5 weeks Filthy quoted. Really disapaointing.
Anyway, suspension went on.
Little man was all about helping me out.
Test fitting the bump stop spacers since they aren’t labeled left or right (this was wrong, the bump stops were too far forward.).
Old 07-28-2018, 04:49 PM #18
Rock sliders
There are a ton of brands that make sliders but I went with with RCI for multiple reasons.
- They are a local small business
- I can pick up in person to save on shipping
- They do group buys to bring the cost down
- I’ve always really liked the visual profile of the kickout on their sliders, they are in my opinion the best looking sliders on the market
- They are one of, if not the, strongest set of sliders out there. They have a 2" square main tube (vs. the common 1.75" round tubes) that is angled on the ends to avoid hang ups, 1.75" DOM outer rails are standard, there are 4 legs on each side with 1/4" steel gussets each one of them, and its full length frame plate mounting that is completely bolt on. They did not skimp anywhere, badass product for sure!
After replacing the suspension and getting all for the XREAS lines and components off the frame I started on the sliders. The Limited rocker panels don’t play well with sliders because of their size. There are a few solutions out there - buying OEM trail rockers which are very pricey, going with Shrockworks trail rockers with are steel, pretty generic in the fitment, and expensive when you factor in paying shipping, or seemingly the most common option, removing the rocker panels and running without them. I didn’t want to spend a bunch on money on replacing the rocker panels so I opted to go with removing them.
To start I grabbed a wire brush and some sand paper. I cleaned up surface rust and scuffed the paint then recoated the frame where the sliders will sit and let it dry for 24 hours.
From there I removed a rocker and bolted up a slider and starting checking it out. It looked horrible! You lose the front mud flaps, it looks unfinished/broken at the bottom of the fender, and most concerning, there is a big ass gap where the bottom of the door seal is fully exposed. My concern is winter driving, mud flap is gone and your spraying up ice and snow directly onto the seal through the gap between the body and the door. There was no way I was going to run it like this.
So I sat there, had a drink, stared at it for a while *****ing and moaning about the situation and tried to figure out why so many people run it like that. Eventually I worked up the courage and decided to go for broke. I put down tape, marked my lines, traced my sons sand box bucket to get a consistent even radius and started cutting.
I did consider trimming the front and rear ends up a bit so when using the sliders to their fullest and actually sliding on rock I wouldn't destroy the lower hanging sections of the rocker panels. I went back and forth on it but ultimately choose not to trim them any further for a couple reasons. The first is with the paint being silver the alignment of the rocker trims to the bumpers is a lot more noticeable than on darker colored vehicles. If I continued the cut straight across the whole length it would look like something is missing when the front and rear bumpers hang a little lower than the sides. Second is the mud flaps, I know ditching them and posting muddy pics is what gets Instagram likes and whatnot but I’m perfectly ok with not spraying the side of my vehicle with mud and rocks. I will not give up mud flaps, and as with all things, I always prefer OEM quality fit and finish when possible. Third was really considering my intended use of the sliders. The main purpose for them is to have a step, now that its lifted, that doesn’t reduce clearance. The secondary purpose is the kick out to push around trunk trunks and rocks to keep the side of the truck and tire away from damage. And finally, I can spend a couple minutes and pull the rockers and mudflaps if I know I’ll be doing something where I’ll need that extra clearance, but this was never intended to be a rock crawler that's going to constantly drop down onto obstacles.
This was the finished result.
Old 07-28-2018, 04:51 PM #19
Some winter fun
You can never trust when winter will actually end when ski season typically runs into June.
Snow days = powder days
The T4R was plowing snow, this is why I have the oh shit kit and snow tires.
Old 07-28-2018, 04:51 PM #20
Hiking, driving, and offroading around the Continental Divide.
Old 07-28-2018, 04:51 PM #21
We made the trip out to Hanging Lake.
Old 07-28-2018, 04:52 PM #22
Luggin my fat baby up a mountain
overlooking Boulder
Old 07-28-2018, 04:52 PM #23
When you want to offroad at 60 mph you bring out the other toy
Old 07-28-2018, 04:53 PM #24
Old 07-28-2018, 04:53 PM #25
Powder days
Old 07-28-2018, 04:53 PM #26
Bottles with my buddy on the ski trip
Taking bikes out
Old 07-28-2018, 04:54 PM #27
Random mid May snowstorm
Old 07-28-2018, 04:55 PM #28
Old 07-28-2018, 04:55 PM #29
This is where the battery upgrade came in. Little man flipped the rear dome light on in the airport parking garage, didn't notice it during day light and wasn't around the truck during night. Ran the battery down and it was a couple days before we were leaving for a road trip so I decided to upgrade rather than charge it and hope.
Old 07-28-2018, 04:56 PM #30
Littleman straight up LOVES the trailer. Sometimes we'll hook it up for no real reason but because he will ask to "hook on trailer"
255/80/17 , camp , king shocks , limited , rci metalworks
Seattle_SR5's 99 Limited 4WD: Repairs, Upgrades, Adventures and Build Thread Seattle_SR5 3rd gen T4Rs 15 02-11-2020 04:54 PM
dustins '00 limited - build/photos/reviews/adventures xdustin 3rd gen T4Rs 21 08-08-2018 09:55 AM
Photoshop 4runner adventures Knight-Errant General Discussions 17 11-17-2015 12:21 AM
Bodhi's 1998 Limited Build, Maintenance, and Adventures Bodhi 3rd gen T4Rs 8 04-07-2014 11:02 PM
