UltraGuage MX Transmission Codes for 2016 SR5 4runner.
riooso
Toyota SR5
Manufactured 11/2016
Made in Japan
I hope this works for others. I searched long and hard for codes and found these over many hours of trying to work it out. If they are on this site I could not find them. Here are the parameters for Transmission Temperature using the UltraGauge MX that I ran across in this forum. What I got to work is a combo. Sorry I can’t find the original post but here goes.
Codes for 2012-2015 Trans temps *F
(TC)
Tdata: 07E02182
MTch: 6182
RPOS:2808
RCTRL:21
TCTRL:92
X: 0009
/: 0005
+: FFD8
Output format : 00
Left/Right 31
(PAN)
TDATA: 07E02182
MTCH: 6182
RPOS: 1808
RCTRL: 21
TCTRL: 92
X:0009
Y:0005
+: FFD8
Output Format: 00
Left/Right is 31
Programmed "MGAUGE" #3 and #4 because #1 and #2 have special bits so I just did not use them.
The "Trans Temp (TC)" code worked well for me.
The "Trans Temp (pan)" however did not. It read 350 and really never did anything.....
So I changed the (0009, Y:0005) codes to (X:0001, Y:0001). Notice that the RPOS for the (PAN) was the 1808 value. Everything works well. I have an infrared thermometer and measured the pan and both lines going into the transmission cooler and the numbers read by the UltraGauge were about only 10 degrees off but the important thing is that I made multiple temperature check and the (TC) temp would go higher when I accelerated and the pan temp would stay constant till the cooler caught up with it.
I have included the page that UltraGuage sent me and I ended up using the (2012-2015) codes. except the X and Y parameters are different. I am pretty confident that these are the codes needed for my 2016 but the point to be made is that the RPOS values are the same as the (2010-2015) parameters.
Very useful info. For the PAN (MGAUGE #4) settings I initially set to X:0001, Y:0001 and got some wacky numbers. I set back to X:0009, Y:0005 and the UltraGuage seemed to register temps that seemed more realistic.
Thanks!
Has anyone else noticed that whether you set the output format to 00 or 01, it still shows temp in Farenheit ?
Anyone know the normal operating temp and the max ?
Thanks
21 5th Gen
So I know this is an older thread.
I have spent HOURS looking for codes or any instance of someone using the UltraGauge- New 1.4 MX
I am struggling to determine if there are codes even available for the newest 5th gens (I have a '21 SR5P), or do the codes for the 2016 and up work fine.
Is there anyone who has made the leap? I prefer the look of the Ultragauge and its functionality based on reviews from close friends in their vehicles. However, other scanners and gauges like the OBDLink MX+ Come pre-programmed ready to work. They just require a phone instead of a physical gauge.
PLEASE, if anyone has information, share whatever you may have.
TIA
I use the >> ScanGauge II ....
I did the internet to use the codes .... I setup my 1996 IMPALA,2000 SILVERADO and 2016 TOYOTA RUNNER....
I bought one scangauge II ....then I touch the button on the display and change 3 of my vehicles.... look it up see if you want all the engine/transmission/MPG ...
I liked all my transmission fluid temps when towing my 20ft wellcraft boat.
edcultural
