Internet shopping. How to tell if a 4Runner has KDSS without looking underneath?
jmichael99
Some of the 4runners I’ve been looking at are a couple hundred miles away and sales people will be sales people and I don’t trust them. Any other way to tell?
Obviously, it has to be a Trail and/or TRD Off Road model. Beyond that, just ask the sales person to take a photo of the front sway bar and send it to you. Non-kdss models have a sway bar mounted directly to the frame above the skid plate. KDSS models have a sway bar mounted like the linked post: http://www.toyota-4runner.org/1346776-post2.html
It's not a guarantee exactly, but if the sticker is over $41,500 (For a ORP) it probably has KDSS, definitely for any of them with $43k MSRPs
I tried signing up for this. Got through step one but when I get to the register your VIN it doesn't accept it. Am I missing something?
You don't need to sign up to use that. Just drop a vin in there and submit it. I have found There is a glitchy type thing though, sometimes if I put another vin in after cutting out another one it will come back with an error. I just re-load the page then put the different vin in and you'll get the read out. This was the best tool when I was looking around for my new runner by far.
If there’s a small crowd around it arguing, it probably has kdss
Post some links with some photos, and I’m sure we can tell you
OP, I understand the problem is not that you don't know KDSS when you see it, it's that when browsing sometimes vague internet listings of a vehicle that is 200 miles away, it can be difficult to tell whether it has KDSS, and you don't want to tip your hand to a salesman too early.
If the VIN lookup trick doesn't work, I'd say the MSRP is a good indicator.
I get what your saying and I agree that would work for a new one. But for used I don’t think that will really work.
Have them send a photo of the instrument panel when ignition is turned on. Mine has a yellow KDSS light to show it’s working. You can check odometer mileage at the same time.
I found this to be VERY difficult, especially in Texas where KDSS is so hard to come by. I found the way dealerships listed their specs to be all over the map. On top of this, I had some really bad info from a number of dealerships I asked directly. One salesperson told me that every 4runner on the lot had KDSS. WTF? Exactly ZERO of them did.
I finally resorted to going to cars.com and using KDSS as a custom search term. Eventually one popped up in the middle of nowhere and I bought it via text messages and had them drive it down. It worked out great.
Good luck!!
Yeah, the prices are formula driven, so even when looking at more options (3rd row/running boards/all the LE stuff) you can usually pick out installed options from price pretty quickly if you're familiar enough
But don't trust dealer descriptions on their websites
Oh, well then
When I was looking for mine, one place in Texas had one and it was in Amarillo and the price was high. I went to Arizona to get mine. Will be rare in Texas. It's a special order for any dealer in Texas. I hear that all of the Gulf states are like that.
Only thing you can do is have them send you a pic of the front. Mine has an RCI skid plate rather than the factory but you should still be able to see it with a factory skid plate. Make them take a pic like this in high res so you can blow it up.
This worked for me. I ran a bunch of VINs through this afternoon and only one turned out to have KDSS. Ended up being 4 Trails without KDSS and one Trail Premium with KDSS.
Doesn't every 2019 TRD Off Road have KDSS? On toyota.com with California zip code one cannot build a non-KDSS 2019 TRD Off Road version. Also, how does toyota.com VIN check list KDSS if it's there?
Drop the VIN into a search engine. The TrueCar result is usually pretty good.
No. It's a $1750.00 option on TRD OffRoad and TRD OffRoad Premium.
The moonroof is an option, too. But you might find that virtually every ORP in your region has that $630/$850 moonroof installed.
Most I’ve seen do have KDSS. But try finding one with KDSS and no moonroof.
