Nope it was a 5th on instagay.
Man if you find it please send it this way. I'd love to try it.
I think that was a 4th Gen.
Mine is stuck on 24/7 for now. If someone figures it out on a 5th I'm all ears.
I think this is the on you talking about.
Write-up: How to Disable (Bypass) the TPMS
In the mid-eighties I was living in Heidelberg. There was a short time period that the $ to DM exchange rate went sky high so it was a great time to buy a car. We always wanted a Jaguar so I went to the local dealer to see what they had.A carefully placed small piece of electrical tape solves my light problem when I run my 2nd set of wheels and tires with no TPMS sensors.
Pretty sure I came across both gen4 and gen5 methods on this forum.
On the 4th gen it's just disconnecting a cable, then jumpering 2 pins.
On the 5th gen it's just jumpering 2 wires on a connector, but you leave it connected.
TPMS is great for people who don't pay attention to their car's status or maintenance needs. To everyone else it's an annoyance, especially those of us who air down occasionally.
So true and this is where it can help every driver.I asked because the threads I've followed have been inconclusive or simply cover with tape.
I grew up without it. TPMS is a pretty good system, not sure I agree with your blanket statement, no matter we all have opinions. Get debris/nail/screw in the freeway on a long drive, loose pressure, see it before you feel it *shrug* I dunno I think that there are other features far more nanny than that.
I air down all the time, as well as monitor the PSI, I like knowing where it is at, regardless if I am filling, driving aired up or down.
Pretty sure it was forum user [MENTION=144375]dot_tom[/MENTION] that posted the TPMS light mod on a Facebook group.
Yep, VAG did that until they went to the indirect method.
Audis went to indirect, but Porsche has kept individual pressure sensors.
Not sure what VW's use...
Agree with your maintenance comments. Mixed bag for sure.
Here you go.
Hey, that was me. I cannot take credit as I found the how to somewhere in the depths of this forum.
Just disable it all together. I’m now running rubber valve stems also.
Made this jumper wire
Jumped these two wires together. They are 5 & 6 on the tpms sensors module. (Light green and dark green. Right next to each other behind driver dash panel.)
Light is forever gone.
Well seems they might of changed something on 2018.
I shorted 5 & 6 and light is still on. Light green and dark green.
Used a quick splice and no go
Edit
Nevermind use the right size quick splice if you going do this lol.
First try i used one too big didnt even cut the insulation
The wires being so small made it hard at first. Glad to hear you got it working!
Depends on the manufacturer.
My car monitors individual sensors per wheel, and will accept new OEM sensors into the system automatically. When I swap between summer and winter wheel sets, it just takes a few seconds for the car to ID the new sensors.
The 4th and 5th gen runners seem to make it more difficult that necessary. I opted to just disable TPMS completely in both of them. Super easy in the 4th gen, and only a little more involved in the 5th.
What car do you have that senses the new TPMS transmitters? Acura/Honda does, but I didn't think that ant 4R/LC does that currently.
While it may be possible to disable the system, it is a violation and, quite simply, foolish. Prior to the implementation of the TREAD Act, the majority of cars on the road had under inflated tires and a significant amount had pressure that was at least 25% under the placarded value.
A violation of what? #LOL #OMG
