It is dopamine-inducing how perfectly 3 Plano Sportsman mediums (1719-00) fit
andrew4r
At their base, there's about 1/2" of space on either side when perfectly centered -- so if you wanted to build some kind of platform, you could still use 1/2" walls at the base of the cases.
View when stacked is just a hair higher than the side windows:
Update: Of note, the large versions won't fit 3 as they are each several inches wider. The small versions are 3/4" wider than the mediums, so I don't think they will fit 3 across.
It is pretty great. I'm looking to upgrade from my cheap-o bins and these look solid. Can you stack them 3 high? Just wondering how easy it is to get them out of the way if I wanted to sleep back there.
I'll give it a test later, but I'm pretty confident you can.
What's even better is these containers are like $20-25.
I can only stack them 3 high if I orient them sideways. The ceiling slopes back down slightly too soon.
The small version of this bin may work for your use. It is 6" shorter in length, 3/4" wider, and the exact same height (13"). I do not think you could have them 3 across, but you could probably have them 3 high longways.
i have these totes, and still do, after installing my drawers. Quite frankly, i hate my drawers, mainly because these totes are way more practical than drawers.
I have a fridge and slide in back but still use these for trips. Typically four of them organized and labelled as... kitchen, pantry, camp, and clothing. I stack pairs and bungee the stacked pairs to keep them stacked. Of course w the fridge...i am folding the seats flat to travel, but it can be done with only drivers side folded.
For the record, a Plano Sportsman large (1919) can fit longways without impacting the 2nd row ramp. It actually fits quite perfectly.
You cannot place a medium (1719) sideways with the remaining space. I do not own a small (1619) to prove it, but measurements suggest it can be placed sideways in the remaining space -- quite perfectly actually.
Have you figured out a way to secure these down? So few anchor points that I'm unsure this is even possible.
just take it, take it, take my money!!!, although this doesn't hurt the wallet much for form, function and versatility, and visibility.
wayblom
