Best Quality Roof Rack on the Market???
This full-length aluminum roof rack, for the 2010-2022 5th Gen 4Runner, expands on our lineup of tried and true rack systems. Our racks are some of the toughest on the market and are designed to get your gear to the places that matter the most. Explore more and worry less with our industry-leading thick aircraft-grade aluminum side panels and stainless steel hardware. Secure your gear by bolting into one of the 9 extrusion crossbars or by strapping it directly to the side plates. This rack is no drill and requires zero modification to your vehicle.
Normally a 5-6 week lead time, these racks are available to ship within 24hrs of purchase. Available with full height and half height fairings depending on your lighting needs.
Available in Stock at Battle Born Offroad!
CLICK HERE to Purchase
SPECIFICATIONS:
  • DESIGNED FOR: 2010-2022 TOYOTA 4RUNNER
  • PRODUCT DIMENSIONS: 95X47-1/2X2.5
  • CROSSBAR DIMENSIONS: 1X2X47
  • LOAD RATING: 300 LBS. DYNAMIC || 700 LBS. STATIC
  • NUMBER OF CROSSBARS: 9
  • OVERALL WEIGHT: 50 LBS
INCLUDED:
  • (2) Sideplates
  • (9) Crossbars
  • (6) Mounting Brackets
  • (1) Fairing with Edge Trim
  • All required hardware for assembly
Sharp looking product
Clearly your question leads to nothing but opinion answers. I'm sure Gobi will be more than happy to tell you they offer the Best Quality Roof Rack on the Market. :noidea:
Yeah. I’ll go first: it’s my opinion that unless you know you’re going to carry a rooftop tent, you give up a lot of flexibility with the flat top racks. When it’s time for me to get a rack I’ll go for a Gobi. But it’s not an easy decision. The flat top racks are lower profile, and so will permit entry into more underground parking. And that’s a huge plus. But there’s something about the Gobi — maybe that it’s one piece. (Those flat top racks are like having an erector set on your roof.) Or maybe that it’s so easy to strap stuff down to a basket.
But going back to the OP’s topic title, what makes the Sherpa better than similar offerings? All of the features mentioned in the description above are generic and could apply to any of the competitors. I mean, they’re all pretty much the same aren’t they? Maybe the side rails might go inside the brackets or outside the brackets. The real differences are whether they’re made of steel or aluminum, and how well the mounting system discourages leaks.
[Some days I just wake up ornery.]
I bought the Sherpa Crestone and it's great so far. Rooftop tent showed up yesterday. Plan to put it on the weekend. Will update if there are any issues.
Dang.
You have them to ship within 24 hours???
I’m already losing faith in Sherpa.
Ordered a Crestone directly from them on the 24th.
Of course it hasn’t shipped yet. The only communication has been conformation of the order.
I even emailed a question. You think they they told me a vendor had them I’m stock? Nope!!
Dang.
That’s a ridiculous thought process. Why would Sherpa have any control or knowledge over what a vendor has in inventory. That’s on you for not doing your due diligence beforehand.
Dang.
Lead times are clearly stated on their website. Also, the couple of times I contacted their customer service by email, responses were prompt and helpful.
The fact that you a) can’t read and b) expect someone to spoon feed you the location of stock they don’t control is the problem here. Go buy a Gobi, I’m sure you’ll be happier.
Feel better about yourself now?
…The fact that you a) can’t read and b) expect someone to spoon feed you the location of stock they don’t control is the problem here. Go buy a Gobi, I’m sure you’ll be happier.
I’m with Beach on this one. It’s frustrating to think that you have to wait for a manufacturer to fill your order while units sit unsold on a third-party vendor’s shelf. There are mechanisms available to let manufacturers keep track of their vendors’ stock. But failing that, Sherpa could at least publish a list of their vendors on their website.
Like this you mean?
Dealer Locator
I bought a 2021 TRD Pro and ended up sticking with the stock rack. I drilled some holes in the cross pieces and have a couple of Maxtrax mounted. It's not a great rack but good enough for my needs.
