My X-REAS is slowly dying, what would you do?
What’s the procedure the shop uses to replace it?
Should be a safe drain/fill procedures outlined.
(Forget the fill part because it’s not going back on, but you know what I mean)
Get some Bilstein 4600’s and it’s smoooooth sailing.
Good luck getting the bleed valves freed up. Mine were corroded to crap, couldnt budge them. Hence the cutters..
I went with an Ironman Foam Cell system when I went to replace my XREAS. Though I did it for the extra clearance from the 3" lift. I don't do "overlanding" but I do drive a lot of fire service roads for camping/hunting/kayaking and just wanted the extra height. Road ride is comparable but the real benefit is when on anything that isn't pavement. You can get an equally comfortable ride from a lot of aftermarket suspension systems and many of them keep the rig at stock height if you're not wanting a lift.
UPDATE:
I scored a used suspension off a 2021 with only 1500miles on it. This included UCA's, front coilovers (still assembled), rear shocks, and rear springs. All for $250!
I installed everything over the weekend, removed all of the XREAS stuff, and a local scrapper even took all of it away for me, ha. I'll be getting an alignment this week and re-torqueing everything in a few hundred miles.
I also added the 1/2" Cornfed spacers up front, since it was the perfect timing.
My XREAS have also come to the age when they will need to fly away and leave home. Most people who've switched to 5100s or any higher level suspension seem to be happy, but these are samples n=1. Has anyone been unhappy with their switch?
I am planning a no lift/very small lift switch, currently looking at 6112/5160 combo, Dobinson IMS, or (if I feel like spending) the King OEMs. I don't think I need new springs and want a relatively easy install (ie, within my skill level), so any tips/experience/feedback welcome.
I took my XREAS out at 10k miles. My 5100's have around 130k on them and still would do it again. Heck I might have to soon anyways. Not sure of the lifespan of the Bilstein's, but they're holding up insanely well.
Please keep this updated as I'm in the same boat with same options. Looking for something softer and mild lift and non rebuildable is preferable. So basically 6112/5160 combo. :cowboy:
I went with 2021+ TRD PRO take offs. Purchased locally off facebook marketplace. Less than 100 miles on them $1200 with the rear springs. They seem like the best option. Damping tuned to position. 1" lift for us limited trim folks. Maybe slightly more as I understand the sr5/trdoffroad/trd pro has a 1" higher rear ride height compared to our limited, and then the Fox front assembly lifts it 1" over the sr5/trd offorad. So maybe for us limited folks that translates to 2" lift front and 1" lift rear.
I'm just going to leave the hardlines on. Hopefully I find time this to DIY the install into my 2015 as the right front shock is hemorrhaging oil right now... I'm also going to keep the 32mm limited fron sway bar.
No reason for me to do a crazy lift, and when I go offroading I'm in it for the scenery and getting to a nice camping/exploring spot. I'll gladly take the easy bypass instead of the hard sketchy path.
