To Drain & Fill or Not to
Bmnorm2
I've spent some time researching our transmission and it's fluid maintenance procedures. When it comes to changing the ATF there are 3 main options.
1.) Drain and Fill - Replaces ~ 3 Quarts
2.) Fluid Exchange via Cooling Line - Enables essentially a full flush w/o machine: ATF Exchange (using the cooling line)
3.) Flush @ Service Provider
To understand the mix condition of the ATF after drain and fill has been performed several times I made some basic assumptions and iterated.
Assumptions:
- Transmission Capacity - ~ 12 Quarts ATF
- Drain and Fill = 3 Quarts ATF Drained, 3 Quarts New ATF Added
- The drained ATF is homogeneously mixed
- ATF Expiration - 60,000 miles
- Drain and Fill Interval - 30,000 miles
My findings suggest that just using Drain and Fill every 30,000 miles as your maintenance plan for ATF will result in your fluid always containing 6.75 Qts of fluid that is expired. In other words, more than half of your fluid has 60,000 miles or more use on it.
See attachment for graph. There is a bit going on here, so allow me to try to decipher the plot.
Y-axis = Qts of ATF after Drain and Fill procedure is completed. Each column adds up to the total 12 Qt capacity. The column sections represent how many Qts have how many miles.
X-axis = Vehicle Mileage and Mileage on Fluid.
Key: You can calculate the miles on the fluid for each section color. The calculation is performed separately for each column.
So, after performing your second Drain & Fill @ 60,000 miles your fluid consist of:
6.75 Qts w/ 60,000 miles of use
2.25 Qts with 30,000 miles of use
3 Qts with 0 miles of use
After performing your fourth Drain & Fill @ 120,000 miles your fluid consist of:
3.8 Qts w/ 120,000 miles of use
1.26 Qts w/ 90,000 miles of use
1.69 Qts w/ 60,000 miles of use
2.25 Qts w/ 30,000 miles of use
3 Qts w/ 0 miles of use
That's 6.75 out of 12 Qts that will always have 60,000 miles or more use.
Let's shorten the Drain & Fill interval to every 15,000 miles. You can just half all of the mileage values on the plot
So, after performing your fourth Drain & Fill @ 60,000 miles your fluid consist of:
3.8 Qts w/ 60,000 miles of use
1.26 Qts w/ 45,000 miles of use
1.69 Qts w/ 30,000 miles of use
2.25 Qts w/ 15,000 miles of use
This trend will continue and you will always have 3.8 Qts of 12 Qts with 60,000 miles of use or more
After performing your eighth Drain & Fill @ 120,000 miles your fluid consist of:
1.2 Qts w/ 120,000 miles of use
0.41 Qts w/ 105,000 miles of use
0.53 Qts w/ 90,000 miles of use
0.71 Qts w/ 75,000 miles of use
0.95 Qts w/ 60,000 miles of use
3.8 Qts w/ 60,000 miles of use or more
So, i've decided i will be performing option #2 when i reach 60,000 miles.
2.) Drain, Fill, Pump + Repeat - Enables essentially a full flush: ATF Exchange (using the cooling line)
Thoughts?
Your assumption that the ATF expires at 60,000 miles is not true for everyone.
I had Blackstone do an analysis of my ATF at 75,000 miles and not only was it still acceptable, they say it could have gone longer.
I consider myself someone who drives "normal conditions." Good balance of highway and city. Large tires with a little bit of extra weight on my truck. Weekend trips. Offroad trips. Lots of elevation climbing daily. No towing.
Of course this interval would change for someone who drives "extreme conditions."
The nice thing about this chart is you can change your "expiration" assumption and still read it. If you assume 90,000 miles as expiration and 30,000 mile interval, then 5.06 Qts of your ATF will be expired (90,000 miles or more).
15,000 mile interval and 90,000 mile expiration: 2.14 Qts will have 90,000 miles or more.
I just did a drain and fill on my 2012 at 50k miles. My mechanic said it was a good color and saw no issues. I’m a gentle user of my rig and only add about 4k/mi per year to it. I change the oil(synthetic) every spring. I’m thinking I will start doing a drain and fill along with the oil change each year. I’m thinking the used fluid mixing annually with the new will be a better option then letting it go indefinitely as many people do to their various vehicle transmissions. Each year the new fluid will mix with the old with each D/F. While it wont ever be totally fresh it will always be good. In a few short years the fluid will be newer than it is now. Anything wrong with this logic? Seems the easiest way to solve the tranny fluid issue and give me peace of mind.
I suggest computing average mixture miles in your spreadsheet. At 150k, this calculation is (2.85*150k+0.95*120k+...)/(2.85+0.95+...)=68668. on the day you change 3 quarts of fluid.
However, immediately before you change 3 quarts at 180k, the average mixture miles is 68668+30000=98668. This number is high, which is why method 2 is better at reducing overall average mixture miles since most of the fluid is changed if you buy and change 12 quarts.
When I used method 2, the last few quarts drained contained some new fluid mixed with the old. I don't know how much old fluid was changed, I'm guessing maybe 80-85%.
Or one can just have the dealer exchange with all new fluid.
My Toyota dealership charges me $93.00 labor to change all the fluid with their machine when I buy the Toyota fluid from them. They have the best deal on that too.
I paid the dealer to do it, there was a guy on here that messed his transmission up doing it himself.
I got the flush/ fill for like $130 or so, was worth it to me and no ill effects from the flush.
Some say don't flush just drain and fill. Lots of opinions.
I had it done at like 144,000 miles, wish I'd done it a time or two before.
Drain and fill helps by conditioning the overall atf fluid. Also when the oil at the bottom of the pan is drained it takes with it some (not all) of the particle matter. Never the less full atf exchange is better.
Don’t be that guy. The DIY fluid exchange is super easy to do and hard to screw up. Just measure what you pump out, lather, rinse, repeat. Takes less than 1/2 hour to do, which is less time you’ll be spending to/from and waiting at the dealer.
At 84 years old, I am going to be that guy
I'm 35 and I'm that guy. I dropped a pan once to do a fluid change on a previous vehicle and it cost me $2500 for a rebuild. If it happens after the dealer does it I can point the finger to them. I'm beat if I did it. No more trans services for me especially when they are a relatively inexpensive service ticket.
I’m “that guy”. I paid for the transmission service at the dealership.
Lots of reasons as stated.
Another is when you go to sell the car at 200,000 miles and there are two or three transmission fluid exchange services on your Carfax, it gives the next buyer some peace of mind + resale value.
Tar Heels are smart, even if a transplant��. I’m a Tar Heel born, a Tar Heel breed and when I die a Tar Heel dead��. Salisbury native
The question I have is has anyone taken a new vehicle and measured the "3 quarts" removed for the drain and fill? It seems when I did mine I drained more than three quarts...
i did about 5 drain an fills.
drained it
filled it
ran if for a few mins
drained it
filled it
ran it for a few mins
etc
did this about 5 times until i started noticing the fluid coming out was coming cleaner and cleaner unit it looked almost like brand new fluid then let it get up to temp and did the level check procedure. i use about 12-15 qts doing it this way and im happy with the outcome
