Soulprogression108
Aloha, I'm looking for some help on my specific 4runner setup. I just purchased a 2011 Trail Edition 4runner it came with a Bilstein leveling kit as the guy called it. So up front is 6112 they appear to be on the 4th notch with E4-FD1-Z005B50 springs. It also has SPC upper control arms. The rear is 5160 reserves and don't appear to be adjustable height wise. I'm pretty new to lifts to be honest. My old truck had a small lift from factory and I ran it on 31 BFG K02s which was fine.
My question is just about what size tire I can fit on this truck. It's currently on stock size 265 70R17 which is ok, the tires just leave something to be desired and I want to put a taller and more aggressive tire on it. Obviously I can crank up the front setting to the highest and gain some clearance. I'd like to fit 33" tires if possible but am open to 285/70R17 as they're just under 33" I've read a fair bit on here and other forums and I under stand 33" kind of fit with a leveling kit, but also a lift doesn't make a difference unless it's a huge lift.
Seems like I might have to do some trimming which I'm ok with if it's nothing crazy. See I also have a set of the original Trail Edition wheels and I know they'll sell easier with tires on them so I want to upgrade my tires on the TRD pro wheels it has on it now and take the 265s and put them on the trail edition wheels to sell as a package.
Any advice is appreciated I'd imagine someone on here has the same suspension and can offer some advice. Thank You!
