Hi all,
I'm scratching my head a bit on an issue I'm having with my 2015 Trail. I have started to notice uneven wear on both front tires - they are both wearing on the inside ~1 inch from the edge of the tire.
Bit of background and sequence of events below:
1) Started at stock height with stock suspension and Cooper Discoverer AT tires. Tires were on the car when I bought it so I'm unsure of mileage but I'd say ~30k kms. No noticeable issues or vibration.
2) Installed new Bilstein 5100 shocks, front and rear, went with the mild lift at the front (0.85" I believe). I loosened the camber bolts during the install to help in getting the strut out/back in. Tightened back up after install.
3) Took the car for a wheel alignment. Mechanic said it was slightly out of spec and they adjusted it without much effort. As far as I know wheels were not balanced, only aligned, but with no vibration before I didn't think it needed it.
4) Drove ~6000kms on a big road trip. Noticed significant vibration through the steering at around 100km/h. Started to notice the uneven tire wear during the trip.
5) Got back from the trip, still getting vibration through the steering. Took it to another mechanic who said the alignment on 1 side was slightly out, but nothing major. There appeared to be slight cupping on the front tires. Re-aligned and rotated rear tires to the front. So far I think the vibration is reduced. Haven't had a chance to properly test.
Now I am going to monitor the tires that were rotated to the front to see if they develop the same wear. But the whole thing has me a bit stumped. I am hoping to get new tires soon so want to make sure this is sorted so I don't ruin a new set.
Any thoughts or ideas on what to check next would be appreciated!
