? Need to Replace '18 PRO Suspension - with what?
TerpRunner
Hi Everyone!
I'm in need of replacing my 2018 TRD PRO suspension due to wear and tear.
I want to keep the stock height, or possibly level out the front.
What do I need to buy part wise? BTW looks like a front coil spring broke, not sure the condition of the rear springs, and maybe some leakage in the back?
I do no really want to add any height to the vehicle! It's already hard enough on the rest of my family for its height.
TYIA!
what do you use your 4runner for? you can spend a little or you can spend a lot
replace with fox or bilstein is probably sufficient if it's a family vehicle. bilstein 5100 are adjustable and can be used to level the front
Hi Everyone!
TYIA!
dobinsons set up is solid
bilstein 5100s all around
6112 upfront / 5100 in rear (5160 is same just with reservoir)
I second the Dobinsons setup - got mine from Exit. Installed bumpers, sliders, etc. and had to lift the rig as she was sagging a bit. It's dialed in real nicely and works great. I know you are stock with no lift, but Exit would have a setup for that as well. Give him a call.
Who is Exit ?
Me personally I would go a Bilstein 6112 and 5160 in the rear, the Pro had Bilstein in it for 2018 I believe and it will be a similar setup with whatever spring you choose. I run 6112 on the front of my 2018 trd offroad and love them, have like 106,000 miles on them now and they perform really good depsite the abuse I have put them though. I got mine at Suspension Lifts | Suspension lifts for trucks total for the fronts when I did it were like $750 back in 2018
Who is Exit ?
Exit Off Road. He has a couple of threads on here, one for 4th gens and one for 5th gens. Mike @ Exit is the sales rep for Dobinson suspension, I bought my Dobinson IMS shocks from him for my '03, very satisfied.
