Deck lamp switch
92-SR5
I have a oem deck lamp switch I pulled from my 88 4runner, i want to hook it up to run some fogs in my 92 4runner. Does anybody know how to wire these? There is 5 wires coming out of it.
I know there is a ground, power out and in, however I don't know what the other two do? Anybody done this before?
Red
green with white stripes
green with red stripe
white with a black stripe= GROUND
solid green= 12vdc
I will get the rest for you later.. all i can remember off the top my head. I know the other wires are used for the switch on and off and the light that is one the switch itself.
It's a SPDT switch with an indicator lamp.
Green is the common terminal of the switch, typically +12V
Light Green/Red stripe is one position of the switch
Light Green is the other position of the switch
Light Green/Yellow stripe is one side of the lamp, typically +12V
White/Black stripe is other side of lamp, typically ground
Did you ever figure it out? I wanna do the same thing.
Sent from my VS501 using Tapatalk
92-SR5
Last Activity: 09-16-2016 06:57 PM
wire the relay like you would any other light circuit
just integrate in to the circuit
erinobr2000
