22-R Toyota Racing Engine
etsola
Toyota 20/22r Race engine.
Details:
-3000$ ENGINE ONLY.
-4000$ PACKAGE (SEE LOWER FOR DETAILS)
Exact same engine as : http://www.toyotacatalog.net/M1WebG...UniqueID=7D5AAE76-A7D5-4905-BC8B-D4629504D744
This race engine has been completely rebuilt, with only racing components or OEM components.
This engine has 0 miles on it.
Estimate power: 200 ft-lb and 210HP OR MORE!
-1978-1980 20R blocks bored at 93mm, honed and resurfaced by a professional machine shop.
-Compression ratio of 12.3/1, need a minimum of 105 octane fuel.
-1978-1980 20R head, with no mechanical fuel pump hole. (Better air flow than 22R or 22RE).
-The Head is professionally bean port and polish, Intake ports are 44mm and exhaust ports are 41mm.
-The head was cleaned up, resurface and reground the valves and valves seats by a professional machine shop.
-Oversize stainless steel valves, 48.5mm intake and 40mm exhaust.
-LC Engineering racing double valves springs, with titanium retainers.
-LC Engineering stage 4 camshaft.
-LC Engineering adjustable cam gear.
-Double row chain.
-Weber intake manifold for 45DCOE carburetor is port match with the head and for the carburetor. (the intake is included in the package deal only)
-Oil pump and water pump specs checked, they are in mint condition.
-New OEM Toyota Alloy 22R rocker arms, greater ratio.
-JE pistons and new Total Seal rings.
-Cosmetic steal layer head gasket.
-ARP head studs and rods bolts.
-Rods and pistons are balanced to be all equal.
-Rods are shot pinned.
-The crank shaft was professionally knife edge machined and polished to increase engine response.
-The crank shaft bearing surface was professionally re-polished.
-The front pulley and the flywheel are lightened (the flywheel is included in the package deal only).
-The crank shaft, the front pulley and the flywheel was professionally balance separately and in one unit
-All bearings are OEM Toyota.
-This engine was professionally reassembled and every clearance on this engine was check and recheck.
N.B: This engine is freshly rebuilt; it means it has 0 miles on it so you will need to do a brake-in period on this engine. And I recommend using regular mineral oil for the brake-in period before using synthetic oil. After the brake-in period I recommend heavy full racing synthetic oil, like 15W50 or so.
!!!This is a race engine so it means there is NO warranty, like any racing components. It’s sold as is!!!
Personally I was running this engine in a race car with 36° of crank advance and 16° of ignition advance, but with 110octane racing fuel and high performance ignition system. Rev limiter was set a 6500RPM. Don’t forget the big radiator and good oil cooler!
One thing I can guarantee you this engine is pulling like no other NA 22R engine.
Reason of selling: New home, baby, New priorities!
PAKAGE DEAL:
-Weber intake manifold (port and polish and port match with the head and the cabs). You will need to use an inline thermostat, there's no place for a regular one. Value*: 375$
-2 Weber 45DCOE9 cabs, 9 series outperform regular DCOE. (they are made in Italy not in Spain) Value :1020$
-New set of floats and different sizes of jets for the carburetors Value*:105$
*-LC Engineering Celica 4 to 1 header with ceramic coating. (little dent at the end of the header but no crack and little fade of the coating in the same area, not a big concern) Take a look at the pic. Bongs for an EGT and for O2 sensor. Value :370$ with no bongs
-Light weight flywheel, freshly resurface. Value :325$
-New Bully performance clutch kit, Stage-4 good for 600WHP. Value :750$
-Complete distributor (used but in good working condition) Value :55$
-New set of spark plugs. Value :25$
Total value of the package deal: 3025$
If you want extra pics, just ask, I have many more ... internal components, etc...
Shipping info:
For shipping it will be a crate so it is 550$us with no insurance if you want some add an extra 125$us. Those quote are good for Canada and the USA, except Hawaii and Alaska. For other destination please ask before bid.
Pics : 22r pictures by etsola - Photobucket
