1997 Toyota 4Runner 4wd Manual Supercharged 17k OBO San Jose, Ca
Hyo408
1997 Toyota 4Runner 4wd Manual Supercharged Desert Dune Mica 320k Miles
Engine
Head rebuilt at about 315k
Used Heads from Toy Connection
- Heads Hot Tanked and pressure tested, valve adjustment, replaced valve stem seals with OEM.
Replaced all upper gaskets with toyota gasket kit, (all gaskets above headgasket, including head gasket)
New OEM Toyota Headbolts
NEW Magnuson Supercharger - installed 310k
NEW URD 7th Injector - installed 310k
NEW URD supercharger pully 2.1, installed at 315k
SnowPerformance Meth injection kit, installed but currently turned off
Doug Thorley Carb Legal Headers with LCE Performance studs- installed 315k
NEW OEM Coil Packs (3) and New Oem Wires installed at 310k
NGK Iridium Spark plugs IK22 installed 310k
NEW OEM Toyota Fuel Injectors (6) installed 310k
NEW OEM Toyota Knock Sensors(2) with harness installed 300k
Timing belt, water pump, cam seals(2), crank seal, tensioner, idler, thermostat/gasket - installed 315k
All hoses in rear of engine and heater valve all changed with oem installed 315k
Deck plate mod for air box
Drivetrain
OEM exedy clutch installed 310k
OEM Flywheel installed 310k
Rear Axle bearings and seals installed 300k
Motul fluid in transmission and Tcase 300k
Toytec front diff drop
Emkieth rear pan hard drop/rise
Brakes
Powerstop Tundra Brakes installed 312k
-Rotors
-Pads
-SS Brake lines
-SS Rear extended Brake Lines
OEM Brake Master Cylinder installed 312k
OEM Parking Brake cable
New shoes and drums
Suspension
Bilstein 5100 with toytec springs
Bilstein FJ Rear Shocks with LC springs, 8.5 wraps
Super pro front lower bushings
Airlift 1000 rear air bags
Reman Steering rack with energy bushings
SPC Upper Control arm
Interior
99+ center console with parking brake
99+ Rear cargo Storage
99 Front driver and passenger seats (lumbar support)
window switch relocated
Snow Performance boost gauge with meth controller
Ultra Gauge OBD gauge with mount
MISC
Radiator replaced
Condensor replaced
2001+ Crystal Tail lights
Weather tech floor liners
Viper 2 way alarm with autostart
Well Window Visors
Wired for subwoofer
There is a lot more stuff done to the vehicle, I have been fixing and building this car for quite sometime so there is stuff I am probably forgetting.
Was not sure where to host pictures so here a link to the craigslights, thanks for looking
1997 Toyota 4Runner 4wd Manual Supercharged Desert Dune Mica 320k...
REE
