Full FJ Cruiser Suspension Installed
KingZ
Finally got the full FJ Cruiser suspension installed. I got it from a FJ forum member for $150 shipped. It included front and rear springs and shocks, fronts still assembled. They were from a 2008 FJ w/ 3000 miles. Even though they are just the black tokico's, there is a noticeable difference from the stockers with 115,000miles. I also used a 1/4" Toytec spacer up front to level it out some.
Install went fairly well after reading the installs from other members and a buddy helping. No doubt this is a two person job. The only b*#*h part was installing the new rear FJ springs. Did the springs and shocks in 4 hours.
My main goal was to upgrade the springs/shocks prior to new tires this Fall. While I was at it, I wanted to reduce the front rake of the 4th gen. However, did not want the running boards higher in the front. They turned out almost perfect with this setup, maybe a very very slight incline, but nothing noticeable at all. Here are some figures from before and after. Keep in mind this is w/ 50 miles after install and no alignment.
Before - After
Drivers Side
Top of front wheel well: 32 15/16 - 34 1/2
Front of running board: 13 5/8 - 14 3/4
Top of rear wheel well: 35 1/8 - 35 3/4
Rear of Running board: 14 - 14 13/16
Passengers Side
Top of front wheel well: 33 1/32 - 34 7/16
Front of running board: 13 5/8 - 14 15/16
Top of rear wheel well: 35 1/2 - 36
Rear of Running board: 14 1/16 - 14 7/8
Next up I'm staying with stock size tires...Revo2's. I don't think the stock size looks too bad with this slight lift. And, I will retain MPG's and spedo accuracy. I also didn't want to buy an extra tire for the spare, which I would have to if up-sizing tire. I'd rather spend the money on a top of the line tire, than the same amount on a lower quality tire in a different size. If I had a bigger lift, I would consider differently. But at this time my choice is stock size (we'll see if I still think so this Fall:))
Before Drivers
BeforeDrivers_002.jpg~original
After Drivers
AfterDrivers_001.jpg~original
Before Passenger
BeforePassenger_002.jpg~original
After Passenger
AfterPassenger_001.jpg~original
Thank you for the pics thats is exactly what i wanted to see. It looks really good. i've been looking into doing the same minus the spacer in the front. I have the revo2's and they're awsome.
The stock tires actually look fine with that lift. I always thought that a lift=bigger tires but apparently that's not true. Thanks for the pics
Looks great! I thought the same thing about the tires after I did mine but now after having it done for a month or so I can't wait to put a bigger tire on. If you don't want to go to a 265/70 there are two tire sizes in between 245/75 or 255/70's.
Excellent results!!! Is yours a v6 or v8?
V6
FYI...265/70/17 is cheaper than stock size for Revo 2.
I agree, but not if you have to buy a spare:)
I still may be convinced to go bigger. Also, why did the engineers at Toyota not go 265/70 to begin with? I'm thinking there must have been some rationale. My thought right now is stock size Revo2's. It may take a lot of convincing to do otherwise. Maybe you should size up and post pics with the setup:).
OK, now that makes sense. I got the same amount of lift (1.5" front) with the FJ springs and 1/2" thick spacer. Looks like you gained an extra 1/2" from the FJ springs with the v6 (less weight in the front) over me (also depends on sag).
looks great!!!! this is becoming the classic set up. it's perfect for the guys that don't want to lift it too much, want to get rid of some of the rake and have a slightly firmer ride.
Are all FJ OEM shocks made by Bilstein or is there another manufacturer?
Stockers are made by Tokico, any upgrade package of the suspension (such as a TRD, Trail Teams, or Off-Road package) will result in some form of Bilstein shocks. They all ride nice. The Bilsteins are just a bigger shock and can handle a little more. The Tokicos offer a very nice ride, and if you'll be on the road 95% of the time you'll be fine. The Tokicos do fine off road as well.
You can tell the difference in the shocks by their color. Tokicos are black. The Bilsteins either came in yellow for the off-road model or red for the TRD/Trail Teams. I have a 2010 Trail Teams here and haven't climbed under to look at the shocks. I'll get under there and look at what color and number they are on the 2010's and report back. What I said above applied at least through 2008 and I believe into 2009 as well.
Looks great:bigok:
I know the topic is a bit subjective but how do you like the ride/drive? Handling, ride over bumps, braking etc.???? Is it what you had hoped for?
:cheers:
It looks good. I like the factory rake, though, because when people and stuff are back there, it levels out. De-raking/leveling points the headlights to the sky and the arse to the ground when loaded down and looks really Griswald.
While that is the case with the factory setup, the FJ springs are more stiff and sag much less than the OEM. When lifted, headlights need adjusted anyway, so it's no worse than stock. And finally, IMO if you're doing that much heavy loading/pulling, you really need a set of air bags for the rear (which quite a few have done with the FJ setup only to find they're not needed very often).
Looks good to me. I appreciate the details, as I am also planning to install the FJ springs. Looks like you settled my question of what toytec spacer to use (1/2 or 1/4). Since I have the V6 too I think I should see about the same change with a 1/4".
However, I was planning to keep the XREAS on my SE for now though. Does anyone think that you would see much difference with just the springs as opposed to the springs and shocks? Seems like they would be about the same to me from what I have seen of other's change outs. But hey what do I know.
However, I was planning to keep the XREAS on my SE for now though. Does anyone think that you would see much difference with just the springs as opposed to the springs and shocks? Yes, big difference. A few have done leaving the XREAS intact and report good results:bigok: Shocks do nothing for lift. Your lift results will be the same whether you switch shocks or not. Seems like they would be about the same to me from what I have seen of other's change outs. But hey what do I know.
:cheers:
:thanks: I hear the ride is better :lookout:
A few have done leaving the XREAS intact and report good results Shocks do nothing for lift. Your lift results will be the same whether you switch shocks or not.
Yeah that was what I was really trying to ask above. I know the ride is "better" was just wondering if the shocks made a difference in the lift, as I am after pretty much KingZ's results measurement wise. Got to get rid of the dunflops soon and want to do that first.
:cheers:
