Full FJ Cruiser Suspension Installed
Do you have the part # for the spacer you used?
I want to make sure I am looking at the correct part.
It is this spacer, you'll need two.
Si, that's the part: TP14. Toytec was great to work with also. Shipped in 3 days.
Looks great:bigok:
I know the topic is a bit subjective but how do you like the ride/drive? Handling, ride over bumps, braking etc.???? Is it what you had hoped for?
:cheers:
Overall ride quality is much improved. Brake dive and ride over bumps both minimized. It feels tighter in turns and just more solid to the road. My stock set-up had 115k miles and was getting bouncy. Even with the Tokicos from the FJ, the dampening is vastly improved. It is primarily a highway/city driven vehicle so the Bilsteins wouldn't have been put to test.
Cosmetically I love it, and am glad I went with the 1/4" spacer over the 1/2". The running boards are almost perfectly level, and the wheel well space still has a bit of rake.
Looks great:bigok:
:cheers:
+1, I'd love to hear the answser to that question too.
I'll soon be putting on the FJ (TRD) setup on my 4Runner. Hopefully it'll go smoothly and I will not regret trying it myself.:smashputer:
Stockers are made by Tokico, any upgrade package of the suspension (such as a TRD, Trail Teams, or Off-Road package) will result in some form of Bilstein shocks. They all ride nice. The Bilsteins are just a bigger shock and can handle a little more. The Tokicos offer a very nice ride, and if you'll be on the road 95% of the time you'll be fine. The Tokicos do fine off road as well.
You can tell the difference in the shocks by their color. Tokicos are black. The Bilsteins either came in yellow for the off-road model or red for the TRD/Trail Teams. I have a 2010 Trail Teams here and haven't climbed under to look at the shocks. I'll get under there and look at what color and number they are on the 2010's and report back. What I said above applied at least through 2008 and I believe into 2009 as well.
I picked up a set from a Trail Teams FJ and the Bilsteins were silver with blue dust covers. I dont remember which year FJ it was though but I would imagine it was pre 09 since thats when I did the install.
I think you'll like it. There has to be 20-25 (or more) who have done it. The only negative feedback(s) I've seen are clemsonexplorer who has "something" going on that's not working for him and one other who wasn't really negative but did comment on the stiffer ride. He actually called it stiff rather than 'firmer in a good way'.
I don't know what clemson is dealing with. I suspect he's got a combo alignment/tire and maybe something else too. It's just whacky. I hate it for him, he's trying though...
Point is 2people who have tried it are unsatisfied/semi-unsatisfied and all others seem to think it's a great, super-cheap suspension upgrade that will never replace high$$$ coilovers but makes the 4Runner drive as it should have from day 1.
:cheers:
That "too harsh" ride is why I chose the FJ stuff to start with instead of the Bilstein HD, for example. A firmer ride would be just fine but I don't think I would enjoy a harsh ride that bucks or launches the rear end off bumps. This way, I don't spend too much and I'd guess it is a bit less stiff than the aftermarket shocks and struts. If it doesn't work for me, I can always sell it and not be out much $$.
:cheers:
Exactly! You'll like it:D
Install
A couple points on the install. I am a novice driveway mechanic, and had assistance from my buddy who is a mechanic. I definately think it's a two person job, but simply for the extra hands/muscle.
If you read the installs it goes very smoothly...with the exception of the rear springs. It took serious effort/muscle to get the springs into place, although we did it with just undoing the shocks.
Front took longer, but were easier to do. One person can do the fronts. It made it very easy to remove the strut assembly by taking down the skid plate and removing sway bar brackets. This way the sway bar is easily pushed aside for removing struts.
It took me about 3.5 hours for complete shock and spring install.
Where are you guys picking up the used FJ parts? Are you just watching Ebay and FJ message board classifieds? Lastly, if you don't mind my asking how much do 4 springs/shocks typically set you back?
I found mine locally on CL. You can try the FJ Cruiser forum as well- keep an eye out there. They will set you back anywhere from $100-200.
I got mine from the FJ forums. Some get lucky and pick up a set by just paying for shipping. I honestly dont remember what mine cost, but think it was a little over $100. If you are more patient than I am they can definitely be had cheaper. Id say anywhere from $50-150.
This is for both springs and shocks.
It just depends on the deal you can find. Most end up paying $75-$100, maybe more for the Bilstein's. Others get lucky and get them free (only pay shipping if not local). I've seen more than one set on the FJ boards folks were trying to give away.
I'm thinking about getting a set of stock oem takiko shocks and springs also. I have an '07 sport with the XREAS system. Does making this swap eliminate the XREAS? Does the XREAS system make this install much more difficult? Thanks in advance...
Yes, swapping to the FJ springs and shocks (or any new shock except OEM) will eliminate XREAS. Depending on how far you go, XREAS won't complicate things too much. There is a fitting, all you do is unscrew the line and remove the shock as normal. You can choose to leave the rest of the systems (lines and canisters that connect the shocks) or jerk it out (most remove it all as they will not be reinstalling XREAS).
While that is the case with the factory setup, the FJ springs are more stiff and sag much less than the OEM. When lifted, headlights need adjusted anyway, so it's no worse than stock. And finally, IMO if you're doing that much heavy loading/pulling, you really need a set of air bags for the rear (which quite a few have done with the FJ setup only to find they're not needed very often).
Good point. Though, I've found two grown people and some day-to-day stuff in the back make my 4Runner just about level.
Agreed. With a female friend of mine in the back seat (no more than 105lbs) and some camping gear in the back, my 4runner was level if not a TINY bit nose high. This was with the 1" toytec spacer lift and FJ install. In most of my trip pictures the car looks level, but a few it appears to be sagging. This could have just been the angle.
Although now I have the daystar 2.5" kit with the FJ suspension and I think its nose high. So maybe the FJ suspension gave me more lift in the front than I was expecting.
turbomikee
