Road Shower / Waterport type showers - something similar that uses a compressor?
TerraCrawler
I have been looking at the Road Shower and Waterport as I wish to have the ability to shower while camping. I have used a similar technology (pressurized bladder) from RinseKit. Although the RinseKit is pressurized, its not a lot of pressure at all, I would like more.
Does anyone know of something like a Road Shower or Waterport that would somehow work with a ARB dual compressor, so that you could have a more pressurized stream? I like the idea that both use a tube, which mounts on the roof, its a nice compact design and I can see where the sun would heat it up nice. I am just trying to think of a way to add a compressor.
Or, for those that have these, is the pressure plenty sufficient?
The Zodi is another option to consider.
https://www.amazon.com/dp/B000RYWQP6/_encoding=UTF8?coliid=I3C23ENTJRDFEN&colid=26RX8SPIBBMF9
[MENTION=147428]Mack1611[/MENTION] thanks, these are pressurized systems similar to Road Shower. I am wondering if anyone has used a siphon based system, whereby you are actually using the compressor and its power to siphon water. I am guessing this would be better pressure than what is achieved via a pressurized tube or bladder.
I have a Waterport. Works great for a quick shower out in the dirt. Add some hot water, pressurize it with the OBA, done. They recently came out with a black one to soak up more sunlight and heat the water better too.
