WARN WL Light Bars, USA Made by Rigid - Discontinued Inventory GB
Chas of MRT
Hey all, WARN is discontinuing their WL Series LED Light Bar Line. These light bars are Made in the USA by Rigid Industries for WARN. These are very similar to the original Rigid E series with a heavy duty WARN bezel. WARN offered a blow out price on them so I scooped up what I could and am putting them on a group buy for you all. Price below are shipped to the lower 48! These are high quality, and check what they sell for from other vendors. WARN is getting out of the lighting game completely and will be concentrating on Winches & Bumpers that fir Rigid products.
The 6" light bar has 12 LED's, 4500 Lumens, 48 Watts, and 3.40 Amp Draw. The 10" light bar has 20 LED's, 6400 Lumens, 60 Watts, and 4.30 Amp Draw. The 20" light bar has 40 LED's, 12800 Lumens, 120 Watts, and 8.60 Amp Draw.
WARN WL Series LEDs are a prime example of a new twist on proven technology. Utilizing cutting edge optical design, Warn Refractec optics provide more overall effective lumens and candela, with less power. The spot beam is in a spectacular 10 degree full width beam, allowing a nice beam spread while still maintaining high candela. The flood wide beam produces a smooth 30 degree flood, without a diffuser, for the ultimate in wide beam efficiency.
Specifications:
Refractec optics
50,000+ hr LED lifespan
Die-cast aluminum housing
UV/scratch resistant lens
Voltage protection
Thermal management
IP68 certified
Designed, engineered, & assembled in the USA
Includes mounting hardware and harness
93930 - 6” Spot - Your cost is $130 delivered Market value is $269 online
93935 - 6” Flood - Your cost is $130 delivered Market value is $269 online
93940 - 10” Spot - Your cost is $175 delivered Market value is $599 online
93945 - 10” Flood - Your cost is $175 delivered Market value is $599 online
93950 - 20” Spot - Your cost is $270 delivered Market value is $849 online
93955 - 20” Flood - Your cost is $270 delivered Market value is $849 online
Delivery is to the lower 48, $30 shipping to Alaska / Hawaii
I don't think he has any pods. I hope I'm wrong.
When does it ends? I need to take some measurements before I make a decision.
Specifications:
Refractec optics
Voltage protection
Thermal management
IP68 certified
What's the dimensions on the 20 inch. Wanted to know if that will fit in the upper grill section on the fifth gen.
Sent from my Pixel XL using Tapatalk
$140 for one spot cube... better go for the Rigid. Better looking, and (wayyyyy) cheaper for the same quality. If you know where to buy of course.
Be warned about dealing with Chas. There was a huge issue with him doing a group buy on shocks. Many people got screwed and couldn’t get s hold of him.
TerryNap61
