spark plugs, differential and transfercase fluid change
RayRay
just got back from Toyota of Morristown and got quotes on certain services:
spark plugs - $160
front and rear differential fluid - $80
transfercase fluid - $50
everything else involved in the 30k service i can do myself with confidence. do these prices sound fair for a dealership? thanks.
spark plugs - $160
Check other threads in the board -- the spark plugs are easy to do yourself. The differential fluid and transfer case are also easy, but it does involve squeezing under the truck. But if you're confident enough to do the rest of the work, you should be able to handle these items.
If you do it all yourself it would be only about $50-80 for 3 diffs and plugs. ;) Stealerships
