How do I know it has KDSS?
It shouldn't cost much. A half hour tops from start to finish for a competent mechanic. I'd ask them to replace it prior to delivery.
I'd also ask them to inspect for any other worn out rubber bushings.
I should add that it's not a critical repair. But if they'll replace it as a condition of the sale, that would be great.
This was the response I got from them, does this make sense?
Well, the bushing is still torn. Regardless of the fact whomever slid it back over next to where it tore off the rest of the bushing, and then tightened the clamp...
Is it critical? No.
Would I fix it? Yes.
But then I'm a former master tech with OCD.
Ways to check if a 2010-2024 4Runner has KDSS:
  1. Dash light: turn the key to ON without starting. KDSS trucks show a yellow KDSS light during the bulb check.
  2. Front sway bar: look behind the front bumper on the driver side. KDSS has a hydraulic cylinder on the end of the sway bar.
  3. Frame: look along the driver side frame rail for hydraulic lines and the KDSS accumulator.
  4. VIN: any Toyota parts counter can tell you from the VIN.
Why it matters when buying armor: some parts fit both and some don't. For example, our Step Edition and Trail Edition sliders for 2010-2024 fit KDSS and non-KDSS. Our 5th Gen skid plates are not compatible with KDSS. Always check before you order.
Cali Raised LED
Philthyphilthy
