FS - 5th Gen ARB Twin Compressor Mount (Pass Eng Compartment) - $115 to $150
bandi
I’m am sorry to say after 15years, It’s time for a break from bandiworld.us fabrication and spend/have more time for family ❤️
As I have always said, this is something I did out of enjoyment and support of my off-roading/over-landing friends ��
Thank You to everyone that has supported this endeavor, it is very much appreciated ����
[EDITED 07/08/2021]
Unfortunately like everything else, my material costs have shot up 20%…. So a slight increase had to be added to these (see below)….
******* I make these to order, So if interested, PM me please ! ! ! ********
Here below are the version of the ARB single/twin compressor mount I currently make...
CANNED STATEMENT BELOW:
VERSION:
1) Mount base version is $130 (5th Gen 4R):
Works with Viair 1 gallon tank (or optional ARB tank - see below)
OR
Works with Shrockworks smog pump relocation kit (No tank option).
2) Mount base version is $140
(07-09 or 10-14 FJ only):
Works with Viair 1 gallon tank.
3) Mount base version for the passenger side is $140 (4th gen only).
4) Mount base version for the passenger side is $140 (GX460/470)
OPTIONS:
a) Add ARB manifold mount is $20 (Wifey $30)... No adapter normally required for the Viair manifold as it has its own mounting tab.
b) Add ARB 1 gallon tank mount is $20
(only for pass. side mount).
c) ARB switch mount (at compressor)is $25 (FJ $35)
d) Custom add-on is $25-35 normally (depending on complexity).
(I also have 1/2” & 1”body lift kits)...
NOTES:
No tank option with shrockworks smog mount option installed.
All versions (except low version) require the ARB port to be rotated 45 degrees as per ARB instructions, a 90 degree fitting installed, and remote air connection.
A lower (non-tank version) base version is available upon request (would allow ARB top mount wire port).
Shipping is a flat $15 for 1-3 day priority mail (US & US territories).
I make these to order (no stock) and there's usually a 1-2 week lead time (this is a side thing between family time to help my fellow overlanders), however when I am back logged it may take a little longer..
No funds required until it's ready to ship and I let ya know, at that one point..
Here are the body lifts I have...
1) 0.5 Bandi Body Lift for the FJ Cruiser (all years) and 4th/5th Gen 4Runners - $69.95 (OUT OF STOCK)
2) 1.0 Bandi Body Lift for the 5th Gen 4Runner & GX460 - $109.95
3) 1.0 Bandi Body Lift for the FJ Cruiser & GX470 (all years) and 4th Gen 4Runner - $129.95
(I also fab’ ARB compressor mounts)
Shipping is 1-3 day priority mail - $9.95
US and Territories only (message me for price on other)..
Let me know, Thank You...
Leroy (bandi)
IMG_3939_zpsyka19ulb.jpg~original
might be interested
I might be interested.
It depends on if i will have enough room after i move my air pump for the dual battery setup.
:bump: :bump: :bump: :bump: :bump:
PLEASE SEE FIRST PAGE
I have two more mounts available, one in which someone did not follow thru with the deal, and another which is the original prototype.
Thank You...
Thank You...
Thank You...
Hey [MENTION=104020]samsung[/MENTION] , see first post if you need a mount for the ARB compressor... depending on your needs, I most likely can make a version that will work...
erinobr2000
