4th Gen rear tire carrier
I have 2 commited right now:
Chiplee
Damengr
I need a minimum of 3 to basically make it worth my time and I will probably only have time to make 5 total. I have room for 3 more orders.
Here's an update on pricing:
Rear tire carrier only (weld on) $650
w/ gas can carrier $725
Hi-lift mounts +$15
CB antenna mount +$10
shovel mount +$20
Bolt-on kit +$65 (tentatively, if I can make it work)
Install by me (welded) $50
Prototype $625 (Chip has first dibs)
small deviations or design modifications may be possible with prior coordination
$500 deposit required with remainder due prior to shipping/delivery.
Some people have expressed concern about weld-on application. With the instructions I'll provide, you should be able to remove your bumper cover (approx. 20 min. job with a screwdriver and 10mm socket wrench) and take it to a trailer supply or other type of local shop that can weld and have the mounts welded on for less than $50.
Just received the final order today.
If I can get them made quickly I may decide to make more but for now orders are closed.:)
vemderglade
