anyone have this happen? mine is leaking between the area where all the connectors are. is this something as simple as an O ring or more complex? i haven't found a replacement yet either and starting to loose more fluid.
Man - I have had the issue you are having now and this is my experience. When my original Master Cylinder was failing, bought one from Advance Auto. It was a re-man in the AISIN casting. It lasted MAYBE two years. I just replaced it with a NAPA part and it seems good. The re-man kit from Toyota is prolly the best route for the $$$$
I wouldn't buy any parts store reman. The only brand I would trust is Advics, which is the name Aisin uses for remanufactured brake master cylinders.
I bought a slave cylinder from advance. Still good![]()
But better than the Aisin that it came with from the factory? Doubt it. A knowledgeable mechanic will tell you that they try not to waste their time with these aftermarket pieces. I've had multiple mechanics tell me that you're better off getting a used master cylinder from a junkyard as opposed to a remanufactured aftermarket piece. Just saying, since they run a business and don't want to waste time warrantying crappy parts.
I've had clutch master and slave cylinders bad out the box. Would not even engage clutch after hundred times trying to bleed it. Or would have clutch drag at high rpm. Aisin is the only way to go.
