strongly consider synthetics
Flush every fluid possible. If timing belt/waterpump has not yet been done it is overdue. Power steering flush will prolong the pump's life. Note: the power steering pump uses Auto Tranny fluid, do your homework before starting.
Strongly consider synthetic diff. oil for both front and rear, and may as well go synthetic oil while at you're at it. I believe Auto Tranny Fluid may also come in a synthetic version. Change that auto tranny fluid frequently, perhaps even more often than recommended. Tranny and power steering ....
Again the presumption is you want to keep this rig running flawlessly. A bit more money on these crucial fluids is cheap compared to replacing parts.
Have the alignment checked... get some opinions on the steering rack, tie rods, idler arms, all of the front end suspension components. Ball joints have been known to fail-usually at around 200K miles, but it can be disastrous so have them checked somewhat regularly. When in doubt change it out, cheaper to replace unbroken parts than risk a road incident, tow bills and so on....
Congrats on your new to you ride. Sport editions highly coveted in these parts:hatsoff:
