03-05 Retrofit with Acme h1?
k3v11n
Hey guys. Anybody do a retrofit on 03-05 headlights using Acme H1 projectors? This will be my first attempt at a retrofit so I'm trying to keep costs low. If anyone has a link or pics on how they mounted the projectors, that would be awesome. Thanks.
acme are the older morimoto line, why not spend a little extra for the current model? most install, u might have to grind or sand the bulb holder tabs of the stock 9006 hole, make sure its flat, then proceed with the install.
There’s are some threads here regarding MiniH1 retrofits, use the search term “retrofit”.
When I first did my retrofit, I used OEM 2006+ housings and swapped in the acme projectors. I ripped them out in a week. They were terrible. better than oem projectors. But not much. I then installed the mini D2S 4.0 projectors. Awesome!! Night and day difference. Basically perfect cutoff and color. Do it once and do it right.
H.Sikina
