turbokidcrx
So I was driving and started hearing a click click click that turned into a thud thud thud and finally a bang bang bang coming from the rear end. I take it to a reputable local shop and the gent there tells me it sounds like a broken tooth off a pinion gear in the differential. So I assume the diagnosis is correct. It's not really driveable unless you want to sound like a giant cherokee drum is approaching, not to mention the whole thing can fail at anytime. So, the question is... repair or sell the truck? Repair was quoted at $2000-2200 including labor. I've looked online for the part and have come across a couple on ebay and thru salvage yards. $900+ seems to be what I've found. An entire rear end can be had for $1400. Labor was estimated at 5 hours.
Rear shocks should be replaced, possible leak in the radiator, front right caliper should be replaced, and cat back exhaust is a must since it's got a couple exhaust leaks, check engine light turns on and off, VSC trac light comes on and off, sluggish to go in gear after hard braking to a full stop. Truck has run solid for YEARS, 139K miles. It's 15 years old. It's in good shape but has some issues. Ideas? What's it even worth? Do I put $2K in it with a used diff and hope for the best? Probably another $1K in other repairs. I love my 4Runner but it's not going to last forever...
