03 SE Full JBL Gut & Replacement
BrightLight7
After all the researching and information gathering adventures; on and off this forum, I finally gutted out all of the JBL "audio"; if that's what you call it, then replaced everything minus the center channel. So this is my build/experience
First, I'll start with a part list: (I know this is the hardest part for many)
  • JL 8W3V3-4
  • Rockford Fosgate RFK4X Amp Kit
  • JL JX500/1d Mono Amp
  • Pioneer AVH-P4400BH
  • Pioneer Parking Brake Bypass
  • Pioneer CD-IU200V USB Interface Cable for iPod/iPhone/iPad
  • RAM Mount iPad mount
  • MB Quart PVL216 6.5 Component Speakers (Front)
  • MB Quart ONX116 6.5 Speakers (Rear)
  • MB Quart ONX4.80 4 Channel Amp
  • Scosche SAT69 Speaker Adapters (Front)
  • Scosche EFX ReVo12 12ft RCA
  • Monster XLN16S-50SB Speaker Cable
  • Pico 1855PT 16-14AWG Flared Vinyl .250 Quick Connect Terminal
  • Metra 70-8113 Wiring Harness
  • Tweeter Adapters (from mjmautoinnovations off ebay)
  • BestKits BKTOYK961 Dash Kit
  • JL XB-MFBU-ANL Master Fuse Block
  • JL XB-ANL150 Blade Fuse 150 Amp
  • Replacement Cabin Air Filter
If I forgot anything, I'll update here.
Everything is waiting to be installed here
First how-to I used to remove the back paneling was: How to Remove the Navigation ECU from a 2003 Toyota 4Runner one thing I'll say if they forgot a bolt. When you follow that, right before you are pulling the panel out, don't forget the bolt in the compartment. Pop that cover open and you'll see it. It's in the picture right behind the bolt he is remember with the caption "There's one more bolt to remove. It's here" There is actually two left at that point.
http://www.toyota-4runner.org/4th-gen-t4rs/62400-replaced-jbl-sub-added-amp-install-pics-info.html
Is Ark Swamp Rider's thread about a similar install with the sub and amp, he has pictures about the grinding out the sub box, though with the W3, you'll nee to grind out alot more. Keep that in mind.
So like others on this forum, I kept the stock sub box and just ground out the plastic clips/rows in the sub with a dremel to accommodate the larger magnet. Word of caution here, be VERY CAREFUL, those rises you see in the plastic at the bottom of the clips, they look raised but have nothing under, please flip the sub box over and look at what I'm talking about, they are raised but not level with the rest of the box. I learned the hard way and cut threw the box and had to melt some of the plastic clips and sand it to get fill the hole. :tinfoil3: Big time waster and near heart attack. I also had to create 4 custom spacers to fit under the stock spacer. Then it fit and sealed up fine. Sadly I have no pictures of the box after the dremel did its work.
Once I got the panel off it looked like this:
When I got the sub box out and looked at the sub...this is what I saw:
Totally blown the adhesive off all the way around. Quick fix but not worth it.
Here is a shot of the stock amp all alone:
Sub box removed from the cargo section:*Only few bolts to remove*
Subwoofers side by side comparison
So after that was installed we started thinking about where to put the sub amp; since it was small enough to place in place of the stock amp that was the idea, but the mounting holes didn't wanna work. So we decided a new master plan! Temporarily place it under the driver seat; above the floor air duct, and order a new cargo compartment that's right above the wheel well, that little cubby thing, so we can grind out what we need to place the amp there and have it still concealed inside that compartment. I'll make another thread when we do that, but that's in the works, just need to find that part.
So sub amp goes under driver seat for now, pics:
Sub Amp itself
Sub Amp almost ready where the seat goes over:
JL Power Distro in use:
I'll say now, running the wires under the carpet and matting underneath was a pain in the ass, used the old coat hanger trick with my WHOLE ARM; upto my shoulder, underneath the carpet as well. Going over that middle hump is a royal pain.
So once that was done, it was just leaving the RCA cables from the sub to where the sub amp would be till ready to place the amp. So the rear was done and put back together and fit fine. Though so reason I blew a brake light bulb during this install. Then the next day the other went, dunno about that but just be careful and check all your lights and fuses after this kind of install!
Then came the door speakers, that was the next task. So we removed the door panels; Screw under the door armrest, Screw at the door release handle, remove the door light, and once you do that pop that sucker off. I managed to break NO clips on anything without the use of any popper offer tools, just rip and pull out from the bottom and up at the top. Before pulling door panel totally off, unplug the lock and window plugs, also unscrew the door release from the door; that screw is on the backside of the door panel; philps head. Then viola. Rinse and repeat.
Also, Thanks to TigerTownAlum, when wiring the front doors, you need to remove the two 10mm bolts when running the wire up door frame and into the actual door. http://www.toyota-4runner.org/4th-gen-t4rs/131863-my-jbl-synthesis-overhaul.html for more info and pics there.
Here is a shot of the Pass door with OEM equip still in
Pass door cleared out:
Pass door with new MB Quart installed
Next plan was once all the door speakers were done was to install the amps.
Well that was easy enough but it was time to run the power cables. The debate was ZERO gauge or FOUR gauge. After already buying 15 feet of Memphis ZERO gauge, I stuck with the Rockford 4 gauge from the amp kit. Why? Well the system wattage I'm running with the 150amp fuse on 4 gauge is safe. It's fine. So if anyone wants the zero gauge, I still have it =)
Here are some shots of the power run and amp setups:
Speaker 4 channel getting ready:
Comparing ZERO to FOUR
**Note: Those hairy beast arms are not my own but they're in fact my best friends**
Battery to firewall grommet with the JL Fusebox:
4 Gauge wire in clips on driver side floor:
Speaker amp ready:
When I did this, I covered the vent with almn foil inside the vent in layers around it then covered the vent in foil itself. The sub amp under the driver side was small enough to fit under the seat and on top of the vent. So no covering was needed there.
To be continued in next post..reached the image limit!
I think this is a good time to point out how we all need to remember to change our cabin air filters more often than most of us do. Well I got my truck in May of 2011, 2003 Sport with 70k on it. I now have 102k, never changed the cabin air filter till this install and...let me tell you...well...I'll let the picture of before and after tell you. *scare you*
I knew when I had the air on one thing before high and it felt like low or one above low, something was up. But never got around to making a new one out of home filters like I've seen people do on here, but while at Walmart, I managed to snag one. NO JUDGING! :lol:
Alright, where were we...
For the the crossovers for the front doors what I did was drill a small hole to fit all 3 wire pairs in and place the crossover in the door compartment with the vents facing up of course. I will double side tape them in place as soon as I get the tape lol.
Here is a shot of what I'm talking about:
or
not sure which I like better just yet
So after running the power, amps setup, sub installed, ready to rawk out with its cawk out. Time to do the HU/wiring harness/dash removal.
First off, I give credit to: How to Remove the Navigation Head Unit from a 2003 Toyota 4Runner
for being dead on for removing the dash. This was accurate and very quick to do. I can remove and install my dash in under or at 5 minutes now. :hatsoff:
Now here is a shot of dash torn apart:
So once it's all apart it's time to wire up the harness, parking break bypass, and steering wheel controls if you got those. It's very easy and just follow the instructions included with all 3 pieces. The orange and white/illum wire will not be connected. It won't affect anything don't worry. So I did research and saw that the Metra kit wouldn't work half the time and was just ugly...So I learned about the bestkits dash kit and when I saw the pictures I feel inlove with the total stock appearance of the sanded down and flat black painted kit. So I did just that, sanded down the front plate with 120 grit sanding block and used a flat black plastic spray paint. Worked out well. The kit fits like a glove...when you're sent the right one atleast. So turns out that for whatever reason; after talks with forum buddy OHP; you can see his posts of his setup in another members thread here: http://www.toyota-4runner.org/audio-electronics/129943-pioneer-avh-p4400bh-install-2003-limited.html I have the non jbl console trim with the jbl setup? or some confusing setup or simply got sent the wrong one with the right part #?
here are some pics of the bestkits front plate not working with my console:
here is a shot with my HU installed and no bestkits front plate installed:
ANYWAYS I wasn't going to let this slow me down, I mean, I've got a badass dremel ffs! So yep, you guessed it...:flamethrwoer2: time to dremel the console!
When I finished, it looked like this!
Sadly enough, I had two hick-ups while dremeling...Hopefully you didn't even notice them from the previous picture ;)
So then I put everything back together and didn't take a picture for some crazy reason...lol
Last thing that had to be done besides adjusting the amps was to install my RAM MOUNT iPad mount. This was supposed to be the no drilling or mod one...hahaha..yeah right...
Just keep dremeling...just keep dremeling...
Here is the bracket after being customized to fit under the seat bolt:
So now currently everything is installed and was working fine till last night when my HU decided it wanted to become defective...that's another thread though, located here: http://www.toyota-4runner.org/audio-electronics/133160-pioneer-avh-4400bh-defective-issue.html
Another thread to consider looking at for a similar strong build is http://www.toyota-4runner.org/4th-gen-t4rs/110628-out-old-new-er.html
Besides that though, this MB Quartz & JL setup is just amazing. It's so clear and just amazing. Puts that JBL system to shame and then some. I know not fair comparison but just...:wow::wow::wow:
So this is my setup and I'll continue to update and change this as new things come up. Feel free to ask any questions needed, I'll be glad to help best I can.
***Edit: Just noticed that for some reason the pictures aren't how they are when I view them on my computer? haha i'll change them so not all sideways either tonight or tomorrow!***
Great write up! I was looking forward to this and you did a great job. All the pics are showing up just fine from my end on this thread.
p.s. I do recommend making your own cabin filter in the future. It can be a pain in the neck to cut/fit, but it's worth the $ you'll save in the long run. I'm glad I did! I got a high end Filtrete filter and it's already been used twice and still has at least 1-2 more uses out of it. I hadn't changed mine in almost 8 months and boy, was I surprised! Mostly just dust, but still gross nonetheless.
Good work! :popcorn:
Thanks, I know I'm missing more rants and raves from the setup but oh well. I'll update as questions arise or I remember.
Yeah, I was going to make my own but I had enough on my plate. I will make the next one myself. Glad to hear that making your own works out well.
Was hoping this was my old 03 SE but doesn't look like it, I've been working through my own rebuild on my new 08. Have a very similar pic actually
IMAG0946.jpg~original
Nice work on getting the onyx4.80 to fit, I didn't even attempt due to it's size.
It fit with some room little to spare. Just sucks I lose an air vent down there.
Yeah, your thread helped me out some too. I just threw your link in there for some credit.:hello:
i think the dash kit suppose to screw on the headunit first, then you put the stock dash back together. dash kit goes behind the actual dash, look at metra manual for the double din dash kit jbl.
I tried everyway possible. If you looked at the pics even that way wouldn't work. I placed the front plate in front of the console before I customized it. Would not fit.
you had purchased the wrong kit, you should of gotten the metra kit with the 2 side peices. its like what i used on my own install.
I didn't purchase anything wrong. Correct model numbers from correct selection from bestkits. Maybe they posted the wrong numbers on this set or something lost in translation, but from my end I didn't do anything wrong.
thanks though
By looking at the original stock trim bezel, the correct kit was metra 95-8202, if you decide to replace the center trim with a new one, u need the metra, if its the limited, the hvac control top peice is a little bigger. And the best kit would work without mods like you did.
The metra looks trashy imo and I did get the best kits and something was wrong with it.
By looking at the unmodded dash, we have the same dash opening, all i have is the base stereo. The bestkits looks like scosche/american international kits, as long you are happy with the mod you had to do is fine, customizing is the way to go to get perfect and differnt result from everyone else.
Only issue now is some reason I can't get any video to display. Not from USB,iPad, or DVD. I'll get the audio it no video. With or without the parking brake engaged. Gonna have to tear the dash apart and look at the wiring harness and see that the parking brake bypass was done correctly.
Do not hook up parking brake, green suppose to match to green on bypass, black goes ground and the blue with the remote turn on. I think that was the bypass i installed with the unit on my friend caddy cts.
Good write-up.
Did u use any of the factory speaker wire runs or pulled all your own?
Pulled all new wire. Nothing factory was used.
I didn't hook to the parking brake. I'm pretty sure I did it correct but I'll take apart my dash and look again soon.
brushbuny
