'03 Windshield Molding
Ducksrus
Junior Member
I had the front windshield replaced, but vendor did not use OEM molding along top of windshield. Could someone with an original windshield molding mind sending me a couple of pics of that molding? I can find the replacement molding, but cannot find a cross section to show the installer. Was going to have the installer review what needed to be done, correctly. Yes, can just order new molding and have installed, but wanted to be sure I had remembered the correct molding. Thanks for the help.
You won't be able to tell from a picture with it installed. It kind of gets pinched/folded, and there is a part that extends below what you can see that gets glued in.
I had problems with mine, but it turns out the installer mounted the windshield about 1/4" too low, so the molding was not compressed enough. You might want a picture of a correctly installed windshield to make sure they do it right.
utkrstam
