Heerefishyfish
So first let me say that I
Heerefishyfish said:So first let me say that I
Heerefishyfish said:Hi Chris,
Thanks for the quick response.
Just to clarify, when you say disconnect the battery, do you mean disconnect it from the car, or disconnect the jumper cables to the Pilot?
I've had the jumper cables off for a while now, so I just want to make sure we're on the same page.
Thanks!
banker1 said:Disconnect it from the car, unhook the negative wire and leave it off for a minute or two, then reconnect. I assume you've let the car idle long enough for the battery to recharge a bit (enough for a restart).
As mentioned above, restart the car do not touch the gas and it should be back in working order. Follow the directions above to reset the windows.
Good luck.
CJ3Flyr said:x2 :iagree: That's what I meant. I have never read a time spec for the T4R. I know some vehicles need up to 8 minutes to reset (older Fords). I might wait a little longer than a minute or two just 'cause I don't know for sure. banker1 may very well be 100% correct, a minute or two may be fine.![]()
banker1 said:I disconnected my battery once to load a hybrid 5.1/ 6.1 Nav disk and a minute or two was all it took for me (had to reset the radio presets, time, windows). As CJ3Flyr mentioned, it might not hurt to leave the battery disconnected longer if you're trying to reset the internal computer. What's an extra few minutes in the grand scheme of things anyway right?
Heerefishyfish said:So, I tried the method of unhooking the negative cable and letting the car sit. I actually forgot about the battery, and it sat for a good 20 minutes.
When I turned the car back on... no luck - the accelerator won't do its job and the auto power windows won't automatically roll down.
Have I missed a step somewhere along the way?
Yes, "discharge" those PCB mounted condensers/capacitors that may be acting like a batt enough to power up a sytem clock. I remember I have to discharge a cellphone board first, before doing a flash. It solves many software and system memory problems. It may have similarity to the ECUMike07SE said:The simple minute or two of the cables disconnected may not be enough for the ECU to reset. When you take you're cables OFF, touch the positive and negative cable's together for a few seconds to drain any residual power in the system and let it stand for ten minutes. Before hooking back up to the battery, touch the cables again for a few seconds. If non of this works in being able to reset the ECU, it's something more involved where you'll have to get a hold of the dealer and see if they have to do any re-initializing of the system.
