04 forerunner wont start, battery fine
mike mccarthy
tried to start car other morning, starter did about half a turn, and battery was dead. eventually got battery charged, cells checked out fine but car just clicks. starter contacts?
mike mccarthy
mike mccarthy
maybe contacts, try hitting the solenoid on the starter a couple times then cranking, if that doesnt work hit the solenoid while you're cranking
also, check if your battery actually has the power to crank, if your alternator is bad jumping the battery was only temporary
delislerebecca
