lives4swell:
the 3/4" NE spacers are just for the front, and basically, you use them instead of the top Revtek spacer. It gives you more room in the wheel well for bigger tires, and evens the truck out so that the rear sits only .5" higher (whereas with the revtek alone, the front was still noticeably nose-down). they cost $100 - which includes the two steel spacers, and shipping. just talk to fourunnabilly and he'll take care of you.
the rest of yousssss :
Please, if you are considering lifting your xreas'd truck, do NOT ditch the xreas ... even with the lift I have lost NONE of the xreas functionability. As for going for a "huge lift" as Vortec suggested, what's the point? Going any higher than 4" is going to tear up the CVs.
You do not need to worry about longer shocks with the Revtek lift because it lifts the rear only 2.5" as opposed to the front which gets lifted 3". If you are really really patient, then you can wait a little while until Billy's company gets his kit out. As previously stated, it will be comprised of spacers, coils, or both, and will be 3-3.5" ... along with that, he is making some different brackets for the bottom mount of the rear shocks so that you can add the lift, then relocate the shock mount easily with a bracket so you don't have to worry about destroying the shocks at full extension, nor will you need to worry about finding a way to replace the stock shocks with longer ones without destroying the xreas.
All in all, I would watch him carefully, and PM him to let him know what you're considering, he'll help you out and take good care of you. He has a 4th gen. also, and although his does not have xreas, mine does, and we've been working to find some solutions for both the xreas'd truck and non-xreas'd.
pm him -- fourunnabilly
I'm pretty sure that if you have a shop install the Revtek kit, they will not take responsibility for ruining your xreas system. Really, this is an install you can do yourselves ... I did it alone (and I mean ALONE!) with HAND TOOLS because I'm poor. If you had an air ratchet and/or other air tools, you'd be done in half the time, especially if you had use of an air tool for the spring compressors. Otherwise, prepare to have Hulk-size forearms.
Also, if you end up doing this yourself, there are plenty of us who would be more than happy to give you our phone numbers so that you could call if you had any problems.
