'05 4runner SR5 Driver's Window not working
Omagunagitya
Driver's Window not functional (not even a sound).
I've spent 2 weeks researching/disassembling/reassembling the doors on my 4Runner. I've replaced the driver's door window switch and the driver's door window motor with no change. I jumped the motor with the car battery at the connector and the motor opens and closes just fine on it's own, separate from the switch; connect them and I get nothing. The fuses and relays (pain to access) all check out and operate as they should. I also checked the continuity of the wiring harnesses and they are all fine. I'm out of ideas.
Anyone had this problem or have a clue what to check next?
Test light at the at the switch and motor connectors. Are you getting power to the switch?
DJNutshell
