'05 SR5 - Front and rear washer fluid will not spray
Bolderboulder
2005 SR5 - 181,000 miles
Both front and rear washer fluid will not spray now, both quit at the same time. The reservoir is full and spray nozzles are not clogged. Does the '05 have a separate pump for the front and rear? I know the front pump is located at the bottom of the reservoir and the right front wheel well cover must be detached to access it.
If there is a pump for the rear, where is it located? And is it the same part number as for the front?
seltzernator
