08 Limited both rear Xreas leaking at 14K
bbumbles
08 Limited both rear Xreas leaking at 14K not too happy going in to be looked at tomorrow then I am sure they will have to order the parts and drag it out. They told me not sure when we can fit you in we are doing recall work I told the girl no disrespect but I could care less I spent 40K on my truck and would like a little service too tell Toyota to build better quality like they use to and you would not be so busy I was pissed!!!!!
Whoa, that has to be the lowest mileage that I can remember where X-REAS has failed.
Tell them, here's your chance to "thank me for being a loyal Toyota customer." Don't tell me about it, show me.
Yep, haven't heard X-Reas failing so early. And you are right, they will have to order the parts. I had this happen to one of my shocks at like 40K. They still had to order the parts. (I have the extended warranty). Total cost for ONE SHOCK and rental car $600.00 billed to Toyota.
Some people have said you can't replace just one, you have to replace the other at the opposite corner. On mine they replaced only ONE. That's the other situation with the X-Reas-even the dealers don't know enough about this "over thought" system to work on it!
There are guys here on the forum that are big fans of the X-Reas. But it does start to become "soft" around 50,000 miles and just goes downhill from there.
I have 74,000 on my '05 and the X-Reas is horrible at absorbing the bumps and potholes from all these storms we have had here in So. Cal.
I have already purchased a stock TRD system from a guy who took it off the FJ. The only reason I haven't put it on yet is because of the extended warranty.
I DON'T LIKE THE X-REAS!!!!:flamethrwoer2:
Well they also told me it is normal seepage is there such a thing i think NOT. I will keep an eye on it I have the 100K warranty plus I have it noted so when it does go i can have a leg to stand on. My wife has an 03 sport 170K no leaks I do have to admit if it was not on a lift getting tires I would never have seen under the dust cover but too funny normal seepage give me another load on crap!!!
That's their pat answer. HOWEVER-HOW IS SEEPAGE NORMAL ON A CLOSED LOOP SYSTEM?
I know that and you know that! I will keep an eye on it make more noise when it gets worse I figure everything they touch they just make worse anyway so I will wait till it becomes more of an issue because it will.
2nd dealer said they are leaking and will order them both. I told them all these problems you would think I had a GM I know that is extreem but give me a break under 15K plus I had a few other issues so far luck of the draw my wife has an 03 170K never been inside a shop yet. oh well....
yep thanks I won't care by that many miles I will just switch to regular shocks but so early we will make Toyota pick up the tab:)
A few years anyway I put over 20K on a year only reason why it looks like low miles is because it was a leftover a year old with 0 miles.
peacefulpiranha
