1" spacer lift
Falls
Super Moderator
I read on here a few day's ago about some who put a 1" spacer lift on front , rear or both ??? Anyone know who it is ?? I thought it was a black truck but could be mistaken.......
I can find the post and can't remember what thread it was in either.......
The member is Snap315 and the thread was about pros/cons of the Cornfed lift.
Quote:
A spacer lift only "levels" out a 4Runner if you get different sided spacers on the front than the rear. For me, I went with the same size front & rear to keep the vehicle "factory level".
__________________
2005 Black 4x4 V8 Limited with:
BF Goodrich All-Terrain T/A KO 265/70/17, NAV, X-REAS, Sunroof, DRL, 6 Disk CD Changer, Side AirBags,OBX Sport Pedals, Chrome Valor Exhaust Tip, Cornfed 1 inch F/R Spacer Lift
Yeah, I had to search for a few minutes to find it myself. I like how his truck looks with that 1" lift. Gives it a really nice stance.
where do you get just a 1" lift for the front? I thought if I put just 1" in the front it would level it out...and then I can put on BFG's 265/70/17's..any thoughts?
I would love it , but am worried about being nose high.
Also you should be able to fit those BFGs without the spacer lift.
Let me know you thoughts. Although I think the full lifts look great I dont really need something that extreme. Just want a not stock little different look and not such a nose dive look.
oh yea, I know they'll fit...it just seems like they are stuffed in there...I thought the front lift might not make em looked so "stuffed". but I surely dont wanna lose the stance that it has now, and I sure dont wanna get into cuttin the 4R with the cornfed....so, I dunno..I wanna beef it up a bit...I guess I'll just think about it for a while longer...
I know what you mean about them looking stuffed.
I did this, get you truck on level ground. (measure the wheel wells) and floor jack the front up an inch and see what you think about the look.
Who do you think makes a 3/4"- 1" leveling lit for the front.
now that sounds like a good idea...I'll try it...
I have no idea who makes the lift...I thought I read donahoe makes one...
Jason,
Would you think a 1" would be sufficient to raise it a little and not have it quite level. I dont want it perfectly level as for carrying stuff in the back or having a trailer on .
Does Cornfed make these to order in any size ?
I would prefer a 1" lift all around. Not too aggressive to compromise cornering stability yet a slight lift. I do not want a front only kit as when I go on vacations, the rear is pretty laden. Having a front lift will just aggravate things and cause my headlights to blind people.
I would agree
Falls said:
You are correct , a little brain fade on my part.
I photoshopped my rig to see what it might look like with a 1" F/R cornfed...see below...subtle, but I like it....
