*** 10AC's Speed Build Thread ***
Sick build man. Love those 305s.
thanks FR4R. after installing the body lift, no rub unless im turning and hitting bump at same time. gonna have to modify a little. love them though but gas milage is crap now!
smittybuilt xrc8 winch
O Yeah.... got this today, but how often will i use it....hmmmm. o well, at least its there when i need it. i may not be able to install it until i get stiffer front coil over springs. i have eibach 600lb now, may need to go 700lb?? i have a plate front bumper and soon to have the winch and sliders installed and skid plates.
Built right UCA's from The Truck Shop of San Diego...
got these bad boys finally. Got them recommended by [MENTION=65101]BrianSD_42[/MENTION] , they look to be a very good quality and what the heck, ill try them out. They are uni ball and come powder coated. Got them installed myself which was fairly easy. they came with everything assembled nd ready to install and pre-lubed. they also have grease zerks for lubing.
while i was at it, before going to the alignment shop, i did also install Energy Suspension red poly bushings on the rack and pinion.
Now that it's aligned with UCAs on how does it drive?
Huge diff?
drives decent. i believe that it could be better aligned honestly. it almost seems its driving same as it did before i got it aligned. i did inspect the bolts on the lower arms to see if they tampered with as far had been used to get aligned with them, i think they are cam style bolts. from my inspect, they were never adjusted. i also will be checking the outer tie rods i put on new and counting threads to see if its the same as i sent it. if so, ill be giving them a call. i also asked them to tighten the upper control arm to frame bolts to torque spec, which they didn't tough at all. i would have but the arms had no instructions nor online either. so I'm sure ill be taking it back.
Sorry to hear. I'd just take it back and talk to James. At least with a small business you can talk directly to the owner.
not a big deal, just needs some tweaking to my liking and its all good. i have been dealing with him from the get go. he is a good guy and sure he will take care of me. i do love those uppers tho!!!
URD 7th
installed my urd 7th injector kit, 190lph fuel pump, and urd 2.2 S/C pulley.
had to install in the glovebox. wanted good access to be able to tune anyways...
all i can say about the install... take your time and have patience and have correct and necessary tools required. double check everything before tidying up. i just took my time and it fired right up and man!! I'm happy!!! definitely night and day difference on more power!! TRD header install will be next!!!
urd 2.2
urd 2.2 pulley installed!!!!
ignore the wood spacer holding my optima...i know, very soon i will be extending the wires doing the big 3 upgrade. the cables don't reach correctly when upright.
URD 7th...
i will be needing to tune the URD 7th ecu. i do get the slightest bit of ping at higher rpm on a gradual increase in throttle from dead stop. i may also be getting a slight bit from low rpm higher speed, but not near as bad without it. hmmmm, guess ill be learning how to tune this. need a serial port to usb adapter to do it.
Laredotx
