115 vac outlet blows fuses
josh1974
I've read everything I can find on the forum about the 115 vac outlet in my center console. It kept blowing the fuses, and I suspect that my inverter is the problem. I removed the inverter last weekend, but I would like to check it and make sure this is the reason. Does anyone have a wiring diagram showing what the pins on the plug to the inverter are for? Or can you tell me what terminals to check on the inverter?
I don't want to buy a new one if it's not the problem. I also wouldn't mind wiring an aftermarket inverter in place of the stock one. I don't need more watts, but I'd like something that will last longer.
BTW, I have a 2008 limited V6
alexaturner
