'15 navi unit work on a '10 non-navi?
Not sure if it will or will not, but in all honesty, you are probably better off going aftermarket. The OEM is not all that impressive. It works fine, but if going through the work to replace the radio, I would get something that has a lot more capabilities.
It will fit in the dash and it will power up. It may also probably work with the audio. But the nav will not work properly, you will be missing wiring that has to connect to it. You can make it work but it will take a bit.
alexaturner
