15x8 chevy rims fit?
avenged yoda
ok so i found the exact style rims i want they are a 15x8 6 lug designed for chevy. im deployed so i can be there to check myself and i cant find any threads so here i am. anyone know if they will fit? also while im here if anyone has 15 in rims how do they like them as far as finding tires for them?
A few things:
Are your 4Runner's stock wheels 15" or 16"?
If 16", you won't be able to use a 15" wheel unless it's of incredibly low offset and you grind the hell out of the calipers, which will still barely leave you with any room likely. Basically, if you had 16" wheels factory, you've got to get at least a 16" rim. Making a 15" wheel fit will be hard, if not impossible with that specific wheel.
They'll fit fine if you have 15" wheels, assuming the Chevy wheel's offset is correct, etc...
15" rims suck pretty hard for brakes. If you have 15" wheels stock (with the stock 15" brakes), then you'll have warped rotors constantly with larger tires anyway.
At least with certain 16" rims or a 17" rim, you can do the Tundra brake upgrade. Tires are more expensive... yes, but you get better choices for size anyway.
A few things:
If he wanted to run 15" steelies, there would be no problem mounting it to any 3rd gen 4runner.
That goes against everything I've read about 3rd gens with larger brakes, but if you say so, you've probably done it. I ditched my 15" wheels almost immediately after I got my truck.
I still think 15" wheels are a waste of time.
My Taco has 15" on it and have had those wheels on my 4runner.
I think there is more range of tires for the 15" wheel. Plus, you can get 33's (285's) C rated while the 16" 33's are mostly E rated.
DSC_0889.jpg~original
I'd be willing to gamble that you have a very select size wheel, because I've never seen anyone who has actually gotten 15" wheels to fit on their 16" wheel truck without grinding the hell out of the caliper, at the very least.
I didn't want OP to think that any 15" steelie will work, because that's simply not true. Chevy wheels, with their ridiculous offsets...? I don't know, I bought a Toyota, not a GM piece of crap.
More tires is probably right, but who wants a DD with a huge sidewall? I wouldn't even dare to think of the sidewall flex with a 15" wheel, 33" tire, and a C load rating. My load D KM2's on 17" rims are flexy as is. Most 15" off road tire selections I see are standard instead of Metric, too.
You can say goodbye to any brake upgrades, because let's face it, stock 3rd gen brakes suck a fat one. A heavy steel wheel and a large tire? You'll be paying more for rotors/resurfacing than you'll save for cheaper tires.
So yeah, there's probably a 15" wheel out there that'll work, but I think it's impractical for a 4Runner.
OP can try it, but if they don't fit, sorry dude. I'm only goin by what I've read on the forums. I remember a while back, a dude got a sweet deal on some 15" Cragar soft 8's... wouldn't you know... they didn't fit over his brakes. Then you've gotta deal with return shipping... choosing the correct wheel... blah blah blah, just choose the right wheel the first time.
Just for kicks, I will try mounting the steelies on the Sequoia to see about the brake issues.
I seam to recall that bigger breaks really don't mean larger breaks but thicker rotors and larger pistons. I believe that the diameter of the rotor is the same. As for the rubbing. The issue is the inside diameter of the rim. The aluminum wheel cross section is 1/3" to 1/2" thick while the steel wheel is only 1/16" to 1/8" thick. So with an an aluminum wheel, you loose up to an inch on the inside rim of the wheel.
Now as far as the mounting face of the wheel. Some aluminum wheel won't fit with the Tundra brake up grade . It is what it is.
As for the tires. I never understood the whole metric and inch size deal.
Why measure a tire height in a ratio that is in proportion of the width and the rim size.
Why not measure the tire by how tall it is and how wide it is?
15in is the stock rim on my 97sr5 so i think they would work. as for the brake issue and tires yall gave me more research....and so goes the never ending pursuit of knowledge. lol thank god for this site.
ghengiskhan
