1983 vs. 1984/1985 Front Axle
You can use any toyota axle and gut it for all the parts then throw them in a trail gear driver side drop axle housing.
trailgear makes an axle housing that uses minitruck diff and outers with their custom axles to perfectly fit a tacoma.
Did all you guys seriously skip over my post? Tacoma Axle Housings and Shafts | Toyota, Suzuki Samurai, and Jeep Off Road Parts and scroll down a bit.
You buy a toyota axle and use the parts off it, and swap it onto this axle. this way you keep all toyota parts, and don't mismatch gear ratios.
Nope. It was already covered.
A-HA! Found it.
Check this thread out.
NorCalPR's leaf sprung SAS w/flipped Toy front - TTORA Forum
Reading another thread sounds like work. What'd he do, flip it end over end and then cut and turn the knuckles?
Read the dam thread. Haha. :brick:
pretty much. WHere the 3rd goes in, in that pic, used to be the diff cover side. Cut cut cover of and drill/tap for studs. Then make thick cover for other side. Barnes4wd now makes a pretty sweet diff cover too which could work quite well.
http://www.barnes4wd.com/Toyota-Heavy-Duty-Differential-Cover_p_228.html
