1988 T4 Problem
lonewolf98765
Hey guys I'm still trying to finish my 4runner but i have run into a problem when i try to rev it up slowly it hits about 1.9 RPM then it drops and it just keeps doing that until you back off. If you push the pedal down harder it will skip over and be fine. Please someone help! any suggestions will be appreciated. Also where could i get some new pipes for the radiator to heat the back?
It is more than likely the tps. Mine does the same thing and I checked for codes the other day and the tps code came up. I will try to adjust it this weekend and let you know if that fixes it
CoaterZ_FL
