1991 t4r
mark10
Just me again. I had a friend pull 2 codes tonight a 25 and a 43 . Sorry don't know where to start. It has a v6 motor 3.0 :fishing:
Code 25:AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
Code 43:STARTER SIGNAL--NO "STA" SIGNAL TO ECU UNTIL ENGINE SPEED EXCEEDS 800RPM
--IGNITION SWITCH/CIRCUIT
--ECU
