1995 2nd Gen Clock/Radio out
dtomp
I have a 1995 3.0L 4x4 and out of the blue, the stock clock and an aftermarket cd player went dead. I checked all fuses in the panel by my left knee and they're good. I checked all my fuses/fusible links under the hood and they're good. I even took the cd player out and checked the fuse in the rear. Everything checks out and nothing else seems to be effected?
Please help.
dome light circuit
the constant power for the clock and radio run through the dome light circuit.
Dome light or acc fuse is in the engine bay/ another culprit is the door switches get grounded out. :lookout:
Thanks for the help...the dome fuse was blown but it went out the side instead of the whole metallic loop. I discovered that when rolling up my windows from the driver's master switch it blows.
are there common issues with the master control that I should suspect rather than spending hours chasing the ground?
