1995 4Runner V6 SR5 AT 4x4 - Parting Out
Do you still have the 2 piece steering column cover?
Located in BC Canada if you're willing to ship...
Here are some pics of it.
100_1140.jpg~original
This part has a piece broken off of it where the screws go into them. The arrow points it out. You can still use the piece, but would need to use a longer screw or just use 3 screws to hold it together.
100_1141.jpg~original
Any word on the best way to ship to you? Is that strike thing still going on or is USPS ok for shipping. USPS is usually the cheapest.
I'll take $10 plus shipping for the part. Let me know.
Ruskymx
Parts
Need rear wind deflector tinted also drivers side running board plastic cover , not the end pieces, Have these? Thanks
I have the rear wind deflector. I'm not sure what you mean by "tinted". It's metal. I also have all the pieces to the running boards.
$25 plus shipping for both pieces. What is your zip code so I can get a quote together for you?
Ruskymx
I'm interested in the rear driver's side running board end cap. Also, if you have any of the rubber gasket thingys (go between the end caps and the body) for the running boards and they're in good shape, I'll take those too.
How much shipped to 92706?
Re: Runner parts
Ruskymx
Thanks for the quick reply. The rear wind deflector I have is tinted plastic, metal would be fine as long as the mounting points are the same, also on the RB, the piece I need is the plastic top face of the left driver's side, (where you step), broke a piece out of it breaking off some ice. I am on the road , will send pics , when I get back ,if you pm , zip 04730. Sounds good .
PM's sent
Does a 95 have an ABS wheel speed sensor? I need the driver's front if it's the same as on a 1998 T4R.
This one does had ABS, but I don't think the wheel speed sensors will work for a 1998. I'll have to see where they are mounted on this. I don't remember seeing them last time I was working on it. I know it has the rear sensors, but not sure about the front.
Ruskymx
The metal portions of the running boards are not in the best of shape. The end caps and the plastic tops are good, but the metal is very rusty and flakey. Scrap if you ask me...
how bout the resistor for the hv/ac switch?
Sorry, thought I responded about that already. Are you referring to the one that's somewhere under the dash by the blower motor? A picture would be helpfull if you have one of the part you are looking for.
Thanks,
Ruskymx
Hello, are you willing to part out the running board, I need the driver side front end cap and do you still have the rear spoiler? and if you do how much to ship it to 94015. Thanks let me know.
do you have an O2 sensor cover? How about the running board end caps including the small strip of rubber on the passenger side, do you part them out? pls lmk. thanks
I do have the DS front, but the part with the clip broke off. I do have the piece that broke off though with the clip
Here's a pic.
100_1045.jpg~original
100_1046.jpg~original
I do have the spoiler yet as well. I need to find a box to fit them in so I can get you a quote. I may be able to make one from a bigger box I have here. Let me work on that and I'll get back to you.
Thanks,
Ruskymx
The O2 sensor is still attached to the exhaust. The studs/nuts are probably going to need to be cut off because they are very rusted. Are you looking for the metal shell that houses the sensor?
I think I may still have the rubber strips, but I have to check and see to be sure. My garage is a mess right now because I had to make room for a new tractor and just started cramming stuff where ever I could to make more room. Let me look and see where they are and if the rubber strips are still attached.
Thanks,
Ruskymx
yes looking at the metal shell that covers the O2 sensor. Send me ur e-mail and send u a picture. What is the condition of the speakers? thanks
leolediola
