1996 4Runner Build - It's the same age as me
Wow, theres a lot of frame/body work to be done there. But stick with it man. Youll learn a ton and it will be worth the experience in the end. And of course the results will be worth it.
Did you have that shop change the tie rod already? Cause thats something you can do yourself and save money. Its really not a difficult fix
es there is a lot of body work. But it runs. Im going to make it so it doesn't look like s h i t but I dont want to spend for ever on it! The lift and tires are where its at :bravo:
And yes the tie rod is done and its done right so I'm over it.
I guess the website was having problems
anyway, 3rd is probably a charm so here it goes
since I live in Quebec (meaning our roads are sprayed with salt like they are trying to marinade it) rust is the biggest problem and I invite you to check under your truck as well, especially the frame. I'm planning on sanding off the rust and hitting it with POR-15 in the next couple of weeks.
Ya I know what you mean. The rust is bad in my area. I have been under the truck and there is rust but no structural stuff. Its still kinda dirty so I want to throw the wheels on it and wash it but I'm still working on that e-Locker.
4Runna4Rumma
