1997 4runner won't start
Hi,
About 2 weeks ago it was 5° here, -10° with windchill. I had to move my truck, I turned the key once and nothing, the power worked but the engine didn't turn over. I turned the key again and I pumped the gas simultaneously and it started. I drove it for about 5 minutes. During this drive the engine was whirring almost like when you're low on power steering fluid... I didn't think too much of it, I just attributed it to extreme cold, especially since everything seemed to be fine prior to this.
I didn't move the car for 2 weeks after this. I went to move it yesterday and I turned the key and got no turn over, no clicking either, but the power worked.
Today it was much warmer 44°, I went back to the car with a multimeter and portable power pack. The battery metered at 12.29, I charged it for 10 min with the power pack and tried to start — nothing, same result. Then I took the pack off and kind of shoved the battery a bit to make sure it was seated properly, I also metered the battery again and it read 12.59 -- power pack was working. I then tried again, this time it actually made a small effort to turn over, but didn't quite start. Then I tried another turn of the key and back to nothing again.
I called a friend for a jump, I charged off their suv for 5 min, then tried to start up and nothing again.
I then tried 30min on the power pack and same result. I also checked my coolant reservoir and it was basically empty...not sure if this could effect the start up...
That's where I'm at. Looking for ideas. Thanks so much.
Possibly your starter. toward its end life it will work somethings and no others. you can smack it with a hammer a few times and try. sometimes that will make it work again but it would need to be replaced soon if thats your issue.
How do I check that? Is that just as simple as listening to the area where fuel is pumped when I turn the key? [MENTION=69868]LittleCaesar[/MENTION]
Checking the fuel pump...have someone turn the key to run while you have your ear in the filler cap...you get about 10 seconds of whine noise...kinda works...best way is taking off a fuel line...which I wouldn't recommend since you ask how to check it.
From what you're describing it sounds like the starter is not engaging and turning the engine to start it...sometimes if you leave the key in start you can hear a electrical whine noise...high pitch...my hearing is shot but that's one frequency I can hear still...hitting the starter while doing the key start will usually get it to go...then you know you need new contacts inside...cost like 8$...easy rebuild...to hit the starter you'll need a long extension or pipe to fit through the wheel well..pass side...tap the top part of the starter...look out for the big wire as it's full batt...its nice to have another person hit the key while you hit the starter but not necessarily needed...oh n it doesn't take much to get it to go so no splitting wood chops needed.
Sounds like your alternator has gone bad.
My wife's Rav4's alternator died. Had a really bad whine when running for about a day, then stopped powering the car altogether, which promptly drained the battery.
Cold weather and no start is a symptom of bad contacts. The low coolant is what bothers me. Try pulling all 6 plugs and inspect for a sign of coolant inside the cylinder. If there is no coolant, replace the starter contacts. Timmy the tool man has a great video about how to replace the starter contacts on a 4runner. Buy contacts from the dealer and it is about $15.
You need to be able to check the cold cranking amps to see if it has enough derriere to kick over the starter.
Yesterday I had a neighbor who had a no crank symptom. The battery was at 12.6 volts but the cold cranking power was only at 150 out of a possible 650 amps. Only a new battery solved her dilemma.
It's not worth buying a tester when you can take it in and get it done at the store...I don't even have one of those!!! It can be a bad battery but they either work or they don't...which is why I'd go after the starter...you can have your meter hooked up and try the starter...if the volts hit below 7 or 8 then it's fried...or the starter has to much load like bad contacts...really gotta figure out where the load stops...I wouldn't worry about the coolant...just top it off and keep an eye on it...see that the coolant is up to the top of the rad cap too when cold.
take the connections off the battery...clean them and the battery posts, re-attach the cables and tighten them down good.
Classic symptoms of loose/dirty battery cables.
[MENTION=107816]onemanarmy[/MENTION] [MENTION=69868]LittleCaesar[/MENTION] [MENTION=303761]WWRD99[/MENTION] I checked the connection posts and collars and they’re clean with no corrosion. I picked up the load tester and got 200 cold cranking amps. From what I’m reading that’s not enough to start the vehicle. Will that change if I take it to be recharged or is it toast and I need a new one? I also tried to start the car again after the test. No clicking, no turnover, no nothing.
If toast, what do you guys recommend as replacement? Thanks so much with help with all
this.
tssawlson538
