1997 t4r
GunslingerT4R
My rear window and wiper are not working. Any ideas where to start looking for a problem? Hopefully its A simple fix
Sent from my SM-G950U using Tapatalk
What about your dome light in the trunk? I had problems with mine and it was the pigtail of wires going to the hatch in the upper left corner. I had wires that were broken.
Could also be the MPXB Fuse under the hood. Mine kept popping because of the wires.
^^This. It's one of the more common causes.
I tried searching but can't find the location of the mpxb fuse. Can someone help me out
I don't think there is a "one-for-all" fuse that supplies power to the back hatch.
Here's a good site that shows all of the fuses for a 1997: Toyota 4Runner Third Generation (N180) (1996 ? 1997) ? fuse box diagram | Auto Genius
Your best bet and first thing to do would be to disconnect the battery and go inspect the wiring harness that goes from the body to the tailgate. It'll be at the very top, next to one of the tailgate hinges.
Carefully peel back/expose the wires so you can inspect them. If the harness is your issue, you'll likely find some damaged wires there.
Sorry, I should have clarified in my other post. You don't have an MPX-B fuse.
It's a '99 - '02 thing. Toyota 4Runner Third Generation (N180) (1999 ? 2000) ? fuse box diagram | Auto Genius
'96 to '98 4Runners don't have one.
Yea o figured that out lol.
That makes sense. My bad. But if you don't have one, then definitely check out the pigtail to the hatch as has been said. You may still have to track down a fuse if the wires shorted afterwards, but try the pigtail first
Yeah I'm going to check it out this weekend. I need to get the rear wiper working for inspection
Try popping off the piece of trim underneath the window. The window motor is in there and if yours is like mine, there is a bundle of wires in there that is torn to shreds. You can jump that motor with a spare battery to verify the motor works.
silly question, but did you make sure that your back window is rolled all the way up? your wiper, etc... will not work if the window is not fully up.
I'll see if I can get to that this weekend. I also noticed the lock assembly is pushed in and dropped down or just not there.
All the wires look good no dry rotted spots or cracks. I'm leaning toward the control module.
