1998 FourRunner Limited part out
Do you still have the lower dash assembly? (Drivers side, under steering wheel)
Also, do you have one of the tan trim hinge covers that go over the rear seat hinges on the floor?
Also a rear hatch latch w/switch?
Also cigarette lighter. Just the part that pulls out. Lost mine!
Brad
Do you have the hardware for the lower dash trim assembly beneath the steering wheel? Also interested in the steering wheel and the black trim piece that sits above the steering column.
Let me know, thanks.
Would you happen to have the passenger side rear fender flare? I just need the section on the quarter panel and not on the door itself.
i don't suppose you'd have the rear wiper motor assembly for sale, would you?
mine is bent, i may have backed into a tree a little bit.
How much shipped to 35601,
for the radiator core support mount with bolt and rubber bushing that is welded to the frame on the right side, it is in the last photo on the left in your first post.
It still has a small piece of the radiator core support on it with the bolt and rubber bushing. I would like to have that piece of the frame so I can gently remove the bracket.
John
?? front and rear cup holders?
Dust cover for the brake shift by pass, tiny little cover by the shifter- allows you to bypass pressing the brake to get out of park?
Lance
