1999 4R steering rack return line fitting part #?
hawkcharmer
Member
Hello,
Im in the process of swapping out my steering rack. Both power steering line fittings at the back of rack were completely seized! I had to cut the feed hard line to get the rack out.
I ordered new Sunsong return/feed lines as a set. I don't think the return line comes with a new line fitting(barb) that screws into the rack.
Does anyone know the part # for this? or is there an aftermarket option? I can't seem to find either one.
I found part# Toyota 44416-04020 but it looks like there is a hose attached.
Any feedback is greatly appreciated! Thank you
Hello,
yes usually you need that little tube nut + metal hard line
the hose set will then plug into that, make sure you get a new clamp to sex things up.
Mike Sargent
